Thread: Delete a vertical curve
    100 Club JeffClark's Avatar
    2002-07
    South Jersey
    153
    Default Delete a vertical curve
    There should be a way to delete the vertical curve without deleting the PVI, but we have not found it.
    Sometimes, when designing the vertical, the AMax fallf low enough that the curve in no longer warented, but the PVI is still needed.
    So we write down the station & elevation of the PVI, delete it, then put the PVI back in at the same place it was to begin with.
    You should be able to just remove the curve.
    2014-08
    455
    Default Re: Delete a vertical curve
    hi
    you can just select delete entity on edit geometry toolbar make sure you select the curve not the tangent
  1. 2019: spiral-curve-spiral s-curve, set tangent to length?
    By Maverick91 in forum AutoCAD Civil 3D - Alignments
    Last Post: 2018-07-27, 02:39 AM
  2. 2018: spiral-curve-spiral-curve-spiral-curve-spiral alignment?
    Last Post: 2018-06-07, 07:33 PM
  3. Is there a way to trim a vertical alignment at a vertical curve?
    By adam.zampino477239 in forum AutoCAD Civil 3D - Profiles
    Last Post: 2012-05-09, 05:25 PM
  4. Station Interval in Vertical Curve Profile
    By mdoty in forum AutoCAD Civil 3D - Profiles
    Last Post: 2008-01-10, 09:23 PM
