Thread: Viewport Grips not Editable
    2023-01
    61
    Default Viewport Grips not Editable
    Good morning.
    I'm having trouble with some of my viewports not giving me grips to edit. It seems to happen when I trim it to a polyline. It hasn't always done this. Is it a setting that I'm missing? Any help is appreciated.
    Turlock, CA
    6,525
    Default Re: Viewport Grips not Editable
    When you clip a viewport, there are two objects overlapping each other, the viewport object and the entity you used to clip it. Turn on Selection Cycling and make sure you select the viewport entity.
    C:> ED WORKING....
    LinkedIn
    2023-01
    61
    Thank you! Just what I needed.
  1. Replies: 2
    Last Post: 2017-08-09, 01:04 PM
  2. Same Functionality of Hot Grips Without Creating Hot Grips
    Last Post: 2012-05-18, 11:52 AM
  3. Worksets editable or not editable has always confused me
    By mthurnauer in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2011-09-14, 01:32 PM
  4. Editable vs. Non-Editable?
    By John.schmidt.212444 in forum Revit - Platform
    Last Post: 2009-06-11, 01:39 PM
  5. 3D arcs with editable grips
    Last Post: 2006-07-06, 11:53 AM
Tags for this Thread
