Thread: Autocad REVCLOUD command
    2010-05
    97
    Default Autocad REVCLOUD command
    greetings everyone. Whenever i execute the REVCLOUD command (in paperspace) it makes the cloud arcs like 1/16. id like it at 1/4. is there a command / setvar command that controls the arc length? so i can change it globally to 1/4
    i typically use the command in paperspace and by selecting an already drawn rectangle around an area. i execute the command and select the rectangle, it changes it, but the arcs are tiny
    thank you for the help!
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,150
    Default Re: Autocad REVCLOUD command
    This command has the options listed on the command line to allow the changing of the Arc length.
    2010-05
    97
    it does, but its not global. it changes it for that drawing session. im looking to change it globally. i assume its a setvar, but i couldnt immediately find one
    2002-01
    jUSt Here (a lot)
    9,150
    You have the following two system variables that control the arc length of revision clouds. Both of these system variables are saved in the registry.
    • REVCLOUDMINARCLENGTH
    • REVCLOUDMAXARCLENGTH
    The Arc Length option of the RevCloud command, returns the average of these two variables multiplied by the current scale of the drawing to provide the current value of this option.
    2010-05
    97
    interesting, i will give them a shot. thank you!
  1. Replies: 1
    Last Post: 2007-03-26, 02:19 PM
  2. AutoCAD 2004 - No RevCloud, Wipeout or AppLoad command
    By CADMama in forum AutoCAD General
    Last Post: 2006-08-04, 09:01 PM
  3. Replies: 2
    Last Post: 2006-01-31, 04:54 PM
  4. Write a LISP routine to enhance the revcloud command
    By melissa.j.seidel in forum AutoLISP
    Last Post: 2005-11-14, 06:08 PM
  5. Controlling the length of arcs within the RevCloud command
    By mom of 3 in forum AutoCAD General
    Last Post: 2005-06-03, 05:54 PM
