Thread: Dynamic Block missing last insertion
    2024-09
    Default Dynamic Block missing last insertion
    Attached Ladder cable tray dwg, when stretched it seems to miss the final rung insertion.
    I am a newby to Dynamic Blocks, what am I doing wrong?
    6,528
    Default Re: Dynamic Block missing last insertion
    What's the repeating distance of the cross member? Shouldn't it start with a cross member? I've never seen a tray with open ends like that.
    LinkedIn
    2024-09
    Every 9" but small offset from start end
    6,528
    See the attached file.
    LinkedIn
    2024-09
    Thanks Ed, what was the problem?
    Sid
    6,528
    To chain an array with a stretch, you need to first create the stretch with a parameter set. Then for the array, don't use a parameter set, just use an array action and choose the stretch parameter to join to it. Then set the array to chain actions.
    LinkedIn
  1. Revit to remember last insertion point
    Last Post: 2014-11-04, 03:23 PM
  2. Replies: 0
    Last Post: 2012-06-13, 08:45 PM
  3. Highlight Last Opened Block in Block Editor Block List
    Last Post: 2008-10-11, 09:03 PM
  4. Replies: 3
    Last Post: 2006-10-24, 03:49 PM
  5. Loose dynamic states from sub block after insertion into master block
    By ANRCREATIONS in forum Dynamic Blocks - Technical
    Last Post: 2005-11-15, 02:41 PM
