Thread: Help Me. How To Make Automatic Block Break Not Break The Line
    2018-12
    Question Help Me. How To Make Automatic Block Break Not Break The Line
    how do I change this lisp so it doesn't break the line
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,177
    Default Re: Help Me. How To Make Automatic Block Break Not Break The Line
    The intent of the routine is to insert a block and trim the geometry found within the rectangular bounding box of the inserted block.
    What is your need to use this routine to insert blocks but not trim the geometry? The normal INSERT command can handle that aspect.
    2003-07
    572
    If you dont want to see the line work underneath the block but not break it add a Wipeout to the block and all done.
  1. Replies: 0
    Last Post: 2013-11-15, 03:50 PM
  2. Make ceiling heights in Room objects automatic
    Last Post: 2013-01-15, 01:58 AM
  3. Annotation - Dynamic Break Line (dyn-break)
    By Kernal_CAD_Monkey in forum Dynamic Blocks - Technical
    Last Post: 2012-07-30, 11:28 AM
  4. Annotation - Dynamic Break Line (dyn-break)
    By barry.40197 in forum Dynamic Blocks - Sharing
    Last Post: 2011-01-13, 03:41 AM
  5. Break line detail component - make center point fixed?
    By patricks in forum Revit Architecture - Families
    Last Post: 2009-01-23, 06:27 PM
