Thread: Area Calculation
    2004-06
    95
    Default Area Calculation
    In the attached drawing there are two shapes. I am trying to scale the one on the right to match the one on the left. The dwg units are Arch. I would like to make them both have the same square feet area but I can't figure out the scale factor. I am using Autocad Map 2004.
    Please point me in the right direction.
    Thanks.
    0,0,0 The Origin
    8,570
    2
    Default Re: Area Calculation
    Here you are.
    Method - divide area of one shape by the area of the other. Scale second shape by the sqr root of the result.
    HTH
    2004-06
    95
    Thanks!!!!!
  1. 2013: Room Area Calculation
    By cowendalton676638 in forum Revit Architecture - General
    Last Post: 2014-08-21, 09:40 PM
  2. SF AREA CALCULATION ERROR
    By FOUTJM in forum Revit Structure - General
    Last Post: 2013-09-26, 08:17 PM
  3. Area calculation question
    By tarch in forum Revit Architecture - General
    Last Post: 2010-04-26, 08:09 PM
  4. Area Calculation ?
    By athanasiosmavrides in forum Revit Architecture - General
    Last Post: 2006-05-09, 07:24 AM
  5. Hatched area calculation
    By alhasanatyk in forum AutoCAD General
    Last Post: 2005-03-04, 03:23 PM
