Thread: Curve Text Orientations
    2005-04
    4
    Default Curve Text Orientations
    Does anyone know of a way to get Labeled Curve Text to flip orientation from "from center" to "to center"? I know Arc Text can do that, but it does not autolabel the curve too.
    Dolly
    Civil Engineering Moderator MHultgren's Avatar
    Central Iowa
    1,428
    Default Re: Curve Text Orientations
    You can create a Tag Label style that places the text on the "Bottom" of the curve by going to Edit Tag Label Styles and typing in a name in the Label Style box, and then selecting the Tag ( and adding any text needed in the Box at the bottom of the dialog ).
    Mark Hultgren
    Just a Lurker
    http://www.MKW-Ind.com
    Blog
    Socializing??
    2005-04
    4
    Thanks, but that is not the orientation I'm refering to. Swapping the text to the bottom still does not change the orientation of the text. It's still upside down. I think this image will make it clearer.
    The bold curve label text is the wrong reading orientation. The other curve text was created using a special lisp routine from my company. That routine is very old and may not be compatable with Civil 3D or LDT2006. I'm looking for a way in LDT to change the orientation of the bold text and still have it align to the curve and be readable.
    2005-01
    100
    Civil 3D will do this for you automatically with no special routines. With Land Desktop, you are out of luck, it will refuse to orient the text other than how it deems appropriate and will not permit you to modify it manually short of using a leader.
  1. LISP from AEC-Curve Text to MText or Regular Text
    By BoarsNest01 in forum AutoLISP
    Last Post: 2010-06-03, 02:46 PM
  2. Curve text...is it possible??
    By Bgy Niugan in forum AutoCAD General
    Last Post: 2008-11-29, 04:30 AM
  3. Text on a Curve
    By bmichell in forum Inventor Wish List
    Last Post: 2005-09-29, 03:20 PM
  4. Text following a curve
    By bmichell in forum AutoCAD General
    Last Post: 2004-08-25, 01:23 PM
  5. Curved Text! Can I automatically curve text around object?
    By IanR in forum Revit Architecture - General
    Last Post: 2004-04-29, 05:22 PM
