Results 1 to 10 of 15
Thread: Notch in Wall
    I could stop if I wanted to kwong's Avatar
    2002-11
    270
    Default Notch in Wall
    Hi all,
    I have a situation where I have to put a notch in my concrete wall - can anyone help? Please see attached (from AutoCAD drawing). Thanks.
    kwong
    2005-04
    55
    2
    Default Re: Notch in Wall
    Does this notch go up all the way. If so then use a vertical sweep profile which is a void. Otherwise you could create a wall based component which cuts into the wall also as a void.
    Could you attach an elevation so i can see what it looks like?
    All AUGI, all the time Arnel Aguel's Avatar
    2003-05
    Philippines
    577
    That is done using hosted sweep reveal create your reveal profile then load it to hosted sweep..It doesn't matter whether or not it will follow the full height of the wall as it can be edited.
    100 Club daniel.hurtubise70031's Avatar
    2004-06
    Montreal, Canada
    153
    Post Re: Notch in Wall
    Try this, i included the profile.
    2002-11
    270
    Hi all,
    Thanks for your response - I tried looking up hosted sweep in the help file but got nowhere. I'm still relatively new to Revit so can someone elaborate on how to go about using the profile? Or point me in the right direction of the help files. Thanks.
    kwong
    2003-05
    Philippines
    577
    Create a new hosted profile as per your section requirement then assign it as reveal category from the settings menu/family category and parameters and save the profile.
    Load your profile in your project then use hosted sweep reveal using your loaded profile.
    All AUGI, all the time gbrowne's Avatar
    2004-03
    Glasgow, Scotland
    579
    Just watch out for the tickbox's for horizontal and vertical on your toolbar when using the sweep command. I missed them for a wee while, stressed me right out...
    2002-11
    270
    Thank you all for your contributions & tips - got it to work, and thanks Daniel for taking the trouble to create that profile for me.
    kwong
    2004-06
    Montreal, Canada
    153
    the pleasure is mine, keep posting if you got more trouble. We love to see new users.
    2005-04
    55
    Sorry guys. I meant to say reveal, not sweep.
  1. Can't Notch or Trim
    By kikky in forum Inventor - General
    Last Post: 2008-10-21, 12:39 PM
  2. Foundation Wall Notch
    By sroy in forum ACA General
    Last Post: 2005-09-19, 07:43 PM
  3. Notch detail
    By robert.1.hall72202 in forum AutoLISP
    Last Post: 2005-06-10, 07:41 PM
  4. Create This Notch
    By robert.1.hall72202 in forum AutoCAD General
    Last Post: 2005-03-02, 09:53 PM
  5. Rafter notch?
    By gjburkett in forum Revit Architecture - General
    Last Post: 2005-01-07, 10:37 PM
