todw
Now we are talking LISP.
Try this code.
(defun C:RX (/ BLOCKS NEXTBLOCK N) ;; Reload all "loaded" xref's only
;; Richard Lawrence (c) 2005
;; Revised code to include required function
(defun ASC (ELEMENT ENTITY /) (cdr (assoc ELEMENT ENTITY))) ;;; retrieve assoc data from entity
(setq BLOCKS NIL)
(setq NEXTBLOCK (tblnext "BLOCK" t))
(while (/= NEXTBLOCK NIL)
(if (= (logand (ASC 70 NEXTBLOCK) 4) 4)
(if (= (logand (ASC 70 NEXTBLOCK) 32) 32)
(if BLOCKS
(setq BLOCKS (append BLOCKS (list (ASC 2 NEXTBLOCK))))
(setq BLOCKS (list (ASC 2 NEXTBLOCK)))
(setq NEXTBLOCK (tblnext "BLOCK"))
(if blocks
(progn
(foreach N BLOCKS
(command "-XREF" "R" N)
(if (= (length blocks) 1)
(princ (strcat "\n"(itoa(length blocks))" reference reloaded."))
(princ (strcat "\n"(itoa(length blocks))" references reloaded."))
(princ "\nNo xref's found.")
(princ)
This routine will check to see if the xref is currently loaded, if so it will reload it. if it is not loaded, it will not reload it.
I hope this helps.
