Hello
I am trying to join 4 walls together but am having problems. All the walls share the same core type, however they have different finish properties (therefore, they exist as different wall types in Revit). When joining the walls individually, everything works fine for the first three walls, but once the 4th wall is added it doesn't seem to want to join correctly. As you can see from the image posted, the finish material is shown separating the wall from the rest of the assembly, but i need the walls to join cleanly to show the interior cores connected. Hopefully this hasn't been answered before, i did a quick search of the forums and couldn't find a solution.
Thanks
Gord
P.S. I also attached a mock file that has the walls in case you want to try it out for yourself. Thanks
