Thread: Dashed (Hidden) Lines in Family Editor
    2005-03
    21
    Default Dashed (Hidden) Lines in Family Editor
    Hello All
    This may be simple, but i don't know how to draw model lines in the family editor and make them show up dashed '<hidden>'. I have made a complex kitchen model, and was hoping to draw the dahed model lines on the doors to show the swing direction in elevation view. I know i could easily draw these after i import the family into the project, but i am curious to see if there is a way to do so in the family model itself so they will show up automatically when i import the family. Any help here would be greatly appreciated.
    Gord
    2003-05
    5,153
    Default Re: Dashed (Hidden) Lines in Family Editor
    Yes. Use the symbolic line - Elevation Swing Projection from the Casework template.
    Bruce Gow.
    Karel*CAD. Application Specialist..
    Architect.
    Revitalize. Blog
    2005-03
    21
    I tried that but i still only have the "Casework - Projection", and "Casework - Cut" line types. Am i missing something?
    2005-03
    21
    Ah, i see. For anyone who has a similar problem you just have to create an Object Style by going to Settings> Object Styles, then creating a new one, in this case called Door Swing Elevation, and then set the line pattern to dash. Thanks for the help everyone.
    Gord
  1. Replies: 3
    Last Post: 2012-07-31, 10:04 PM
  2. hidden lines showing as dashed lines
    By tomcarver in forum AutoCAD 3D (2007 and above)
    Last Post: 2010-09-26, 09:09 AM
  3. Replies: 3
    Last Post: 2007-03-25, 02:19 PM
  4. Cannot create dashed symbolic lines in curtain wall family?
    By cparsons in forum Revit Architecture - General
    Last Post: 2006-04-07, 04:56 PM
  5. Hidden and Dashed Lines
    By IanR in forum ACA General
    Last Post: 2004-07-07, 02:35 AM
