Im running 2006 but this may work in previous versions.
1. With expresstools loaded you can use the command fullscreen to
gain some extra screen space.
2. Right click on the taskbar, choose options, autohide the taskbar. Can
always hit the windows key in order to bring it up. Alt + Tab may also
be used to switch between open programs.
3. Autohide toolpalletes, properties, etc.
4. Use the pgp file to setup hotkeys so you do not need tons of toolbar icons
5. Make sure to keep an icon for save, print, publish, etc. The menus can
be avoided, file/plot can be a crutch.
6. Use the properties toolbar to change color and linetype. Even though the
properties menu is good for editing objects, try using it less; the
properties toolbar can be quicker. The properties menu could potentially
be removed from the screen.
The supplied picture is not that great, but it gives the general idea.
