Results 1 to 10 of 10
Thread: find and replace removing first letter string
    2004-12
    153
    Default find and replace removing first letter string
    I am using 05 and with the FIND command, when i got to find and replace, the first letter string in the mtext will be removed. For instance, I want to find SEE SHEET A1.0 and replace it with SEE SHEET A1.1. When i do the FIND command, it will find and replace the text, but it now will say EE SHEET A1.1. THE 'S' IS TOTALLY GONE. This happens on all mtext strings in the drawings. Any help would be greatly appreciated. Thank you
    13,657
    Default Re: find and replace removing first letter string
    Hi
    Just carried out a quick test here, everything appears to work ok!
    Windows XP Pro SP2
    AutoCAD 2005 SP1 + other available Updates (AutoCAD® 2005 - Updates & Service Packs)
    Do you experience this issue / problem in all drawing files?
    Have a good one, Mike
    2004-12
    153
    It is happening throughout the office with mtext only using the architxt.shx font. The only letter to disappear with the FIND command is the very first letter of the mtext string.
    13,657
    Hi
    I download Font file architxt.shx from here -> Made it available to AutoCAD 2005 -> Created a Text Style based on this Font file -> Carried about testing as before....
    Everything worked ok!
    Therefore do have the AutoCAD 2005 Updates & Service Packs installed on your system(s) (please refer to my above post for further information if need be).
    2004-12
    153
    I am running windows xp service pack 2 with all current updates and autocad 2005 with the service pack 1. I did not see any other service packs to update autocad. This only happens with mtext, and i'm not replacing the first word of the mtext. For instance i want to change "soffit height of counter" to say "soffit height of niche"- it will change it to "offit height of niche". I will keep trying to see if i can find out what's going on. I might have to explode the mtext, run the find command, and then convert it back to mtext if nothing else.
    Thanks again for your continuing help!
    2002-07
    64
    This not really a fix but a possible work around. Try replacing "soffit height of counter" with "ssoffit height of niche". (If it looses the first character, give it an extra pre-character to loose?)
    13,657
    Quote Originally Posted by tyeelaw13
    Hi
    For what it is worth I have "Spelling Checker Update" & Units Toggle for the Plot and Page Setup Dialog Boxes" loaded on top of Service Pack 1.
    Carried out further testing using the exact strings given above, again everything worked ok! at this end.
    2004-12
    153
    OK- I have found the root of the problem, but not sure how to fix it. If i select the text and go to the change properties dialog box, under the contents, the text shows as followed
    {farchtxt.shx; BODY OF MTEXT HERE}
    Does anyone know how to get rid of the {farchtxt.shx; part of the text string?
    Thank you.
    13,657
    Hi
    Have a browse of the following threads -
    Changing text height and style in AutoLISP
    Removing formatting in MTEXT editor
    Can't get Simplex Delta in Leader Mtext
    MTEXT "CONTENTS"
    text with embedded formatting
    2004-12
    153
    Thanks Mike- it was a good place to start. I tried what autodesk suggests, but when i change the text using the STYLE command, it doesn't effect the mtext. I found a lisp routine that strips the formatting off of the text, so I think that's about all i can do. I appreciate all the help!
  1. 2014: Selecting and Removing a Range of Text Values in a String
    By alexewart521206 in forum AutoCAD General
    Last Post: 2015-04-21, 09:05 AM
  2. how to replace only a single string by pre decided string.
    By mohammad.raees637333 in forum AutoLISP
    Last Post: 2014-04-22, 01:07 PM
  3. How do I replace part of a string?
    By aaronic_abacus in forum AutoLISP
    Last Post: 2009-12-12, 06:24 PM
  4. Replies: 0
    Last Post: 2008-05-22, 08:49 PM
  5. Find string in drawing and replace with VBA
    By montana.fox in forum VBA/COM Interop
    Last Post: 2006-03-01, 04:51 AM
