Results 1 to 9 of 9
Thread: How to convert a DWF to DWG
    All AUGI, all the time cadkiller's Avatar
    2003-09
    Bergenfield, NJ
    697
    Default How to convert a DWF to DWG
    Open DWF Viewer
    Go to Menu Edit> Copy
    Open up AutoCAD
    Go to Menu Edit> Paste Special
    Select AutoCAD Entities.
    You will need to adjust the scale and that's it!
    PS: Note that not everything gets converted properly.
    Text and dimensions are exploded; but everything else comes out pretty good.
    2001-11
    53
    Default Re: How to convert a DWF to DWG
    I've tried this and the arcs turn into poly lines. They are really messed up. Am I doing something wrong or does any one else have the same problem.
    2003-09
    Bergenfield, NJ
    697
    The same thing happens to me. Nothing you can do about it; but recreate them.
    2001-11
    53
    Bummer, Thanks for the info.
    2004-12
    The DWF Viewer copy doesn't appear to copy objects printed from model space. I'm only captureing the paperspace objects. I'm using DWF version 6. Perhaps the older versions capture more?
    Member Mike.Craven's Avatar
    2004-07
    22
    I'm using Version 7 and there doesn't appear to be any vector geometry, it will allow me to copy the image, but that has little use for me.
    Member Chris Matira's Avatar
    2005-08
    Philippines
    41
    Quote Originally Posted by cadkiller
    Open DWF Viewer
    Open up AutoCAD
    great tip! it lessens the burden of drawing the whole thing again.
    Earth
    9,802
    R.K. McSwain | CAD Panacea |
    2011-02
    3
    Quote Originally Posted by cadkiller View Post
    Open DWF Viewer
    Open up AutoCAD
    EXCELLENT! Thank you
  1. 2010: convert dgn to dwg
    By mkr_trash in forum AutoCAD General
    Last Post: 2012-10-08, 12:24 PM
  2. Convert a PDF into a DWG
    By huuthu_nguyen82544 in forum AutoCAD LT - General
    Last Post: 2006-08-18, 01:02 AM
  3. Convert DWG to PCX
    By mreynolds9 in forum AutoCAD 3D (2006 or below)
    Last Post: 2006-03-31, 08:52 AM
  4. Replies: 9
    Last Post: 2005-06-29, 09:49 PM
