Thread: Hatching Puzzle
    I could stop if I wanted to kwong's Avatar
    2002-11
    270
    Default Hatching Puzzle
    Hi all,
    I have some walls and columns showing hatching, but try as I might I couldn't hatch the rest of the columns, and 3 of the columns are the same as one that is hatched. Please help.
    See attached.
    kwong
    100 Club JTF's Avatar
    2003-04
    Welland, Ontario, Canada
    169
    Default Re: Hatching Puzzle
    Very strange but if you join your columns to your block wall it takes on the block wall material, if you then unjoin the column it converts back to your concrete material and displays correctly.
    100 Club nrenfro's Avatar
    2003-09
    metro DC
    144
    All I can say is that I have had this same issue also. I was in a rush so I just placed filled regions with the correct catch over the columns. This is not the best way to address the issue but I have not had time yet to look things over. I know now that I am not the only one are their others and has anyone discovered the issue?
    2002-11
    270
    Thanks JTF, that did the trick ; you said strange - is that not supposed to happen?
    kwong
    2002-11
    270
    This fill pattern problem seems to stem from the fact that I am using the defaultAUSENU.rte template. Every time I draw a new column I have to join it to another one to 'force' the fill pattern to appear. I have now copied everything to the Default Metric.rte template and everything's OK - likewise the DefaultUS-Canada.rte template. Can't work out what's different though.
    kwong
  1. X-Ref - Zoom E puzzle
    By U.Rackharrow in forum AutoCAD General
    Last Post: 2007-07-09, 01:50 PM
  2. Labeling puzzle
    By lholt in forum AutoCAD Map 3D - General
    Last Post: 2005-02-10, 02:35 PM
