Thread: Grouping.. maybe..
    Atlanta, GA
    48
    Lightbulb Grouping.. maybe..
    I have code that generate two objects. Nothing exciting. I want to be able to select both objects in one pick, but still have individual grip edit functionality.
    I played with grouping, but got lost along the way. It didn't seem readily apparent that it was the appropriate way to approach the issue.
    Any thoughts? If grouping is the way, and pitfalls to avoid?
    Matthew
    2000-01
    Seattle WA USA
    5,859
    Default Re: Grouping.. maybe..
    Groups will certainly do exactly what you want. Just look into the Group object in the ActiveX documentation.
    Atlanta, GA
    48
    Well, I'll have several hundred in a given file and I'm concerned about file size. I got bit with the layer filters and I'm obviously hesitant about some of the special AutoCAD overhead objects..
    Also, is there a way to make the groups unnamed?
  1. Components Grouping
    By fjtdogeno in forum Revit Architecture - General
    Last Post: 2011-05-18, 11:29 PM
  2. Grouping??
    By pearlx100 in forum AutoCAD General
    Last Post: 2009-09-21, 05:56 PM
  3. Grouping
    By nsinha73 in forum Revit Architecture - General
    Last Post: 2009-02-07, 12:38 AM
  4. Grouping Issues
    By ryanmcin in forum Revit Architecture - General
    Last Post: 2006-02-01, 06:22 PM
  5. Grouping
    By al in forum Revit Architecture - General
    Last Post: 2004-03-04, 10:33 PM
