Results 1 to 8 of 8
Thread: "Object Properties" Toolbar Customization
    Member dhurd's Avatar
    2004-01
    14
    Default "Object Properties" Toolbar Customization
    Is there a way to customize this toolbar? I want to expand the "Layer" section so that the names are not truncated with ellipses. Is there a dcl or similar file that defines it properties? Thanks
    Turlock, CA
    5,702
    Default Re: "Object Properties" Toolbar Customization
    Sorry, its an arx control...Not editable.
    C:> ED WORKING....
    2001-05
    Austin, TX USA
    2,201
    Probably not quit what you want. But....
    Check out QuikPik from Menusoft. It won't expand the toolbar itself, but it will expand the drop down. It widens it and it drops down further so you see more of the layers at once. Does the same for the other pull downs as well. Plus it several other things that are nice. There is a demo you can try for 30 days. Well worth the price.
    Glenn Pope
    Civil Designer/CAD Manager
    River City Engineering
    AutoCAD Civil 3D 2011 Ver. 3
    Windows 7 Pro 64bit
    I explode MTEXT.
    2004-01
    14
    Is similar code for the pulldown also unavailable?
    2001-05
    Austin, TX USA
    2,201
    Here is a screen shot of what it would look like. I think this will answer your question. If not let me know.
    Glenn Pope
    Windows 7 Pro 64bit
    I explode MTEXT.
    13,656
    Hi
    Might want to take a look at FixCombos (freeware) from CADwerx
    Have a good one, Mike
    2004-01
    14
    Thanks all.
    The Quickpix makes my Acad platform unstable (Fatal Errors). The CxFixCombos from cadwerx is smaller and seemingly stable. To customize the width you change registry keys. Does the base "Object Properties" use registry keys also for setting width? I hate messing with registry values unless I'm certain of exactly what to change.
    100 Club lance.81922's Avatar
    2005-01
    Santa Fe, NM
    176
    I have been looking into this, having written other programs that read and write registry keys to move the command line box and various toolbars. So far I have not been able to find where the info for the Object Properties dialog is stored. I think that programmatically altering the registry is a lot safer than manual editing.
  1. Replies: 13
    Last Post: 2015-01-26, 01:35 PM
  2. Replies: 2
    Last Post: 2014-10-17, 04:57 PM
  3. Object Properties "Contents" Code -.66667x
    By chillme1 in forum AutoCAD Annotation
    Last Post: 2007-08-01, 05:33 PM
  4. Replies: 8
    Last Post: 2006-08-16, 02:20 PM
  5. System variariable for "invert filter" and "apply to layers toolbar" checkboxes
    Last Post: 2005-11-23, 05:58 PM
