Results 1 to 8 of 8
Thread: Modify the color of the UCS icon via LISP?
    2005-04
    Angry Modify the color of the UCS icon via LISP?
    Does anyone know how to modify the color of the UCS icon via LISP? I have not been able to find a system variable or command-line-only option. My programming skills are pretty feeble, but below is the code (so far) of what I'm trying to accomplish:
    P.S. - I use AutoCAD 2000i.
    Thanks!
    S.P.
    ; This is a command to rotate the display orientation incrementally by 90 degrees (for fold-out type plans/elevations).
    (defun c:display-rotate ()
    (setq iconstate (getvar "ucsicon"))
    (command "ucsicon" "on")
    ; I WOULD LIKE TO MAKE THE UCS ICON RED AS A REMINDER THAT THE DISPLAY ORIENTATION HAS BEEN MODIFIED
    ; Rotate the UCS 90d, then use "plan" to have the display match the new orientation
    (command "ucs" "n" "z" "90")
    (command "plan" "current")
    (princ "\nUCS and Display Orientation have been rotated 90 degrees.
    \nUse the command [ display-restore ] to return your view settings to normal.")
    (princ)
    (defun c:display-restore ()
    (command "ucsicon" iconstate)
    (command "ucs" "w")
    (command "plan" "w")
    (princ "\nUCS and Display Orientation have been restored to normal.")
    (princ)
    ; I'D EVENTUALLY LIKE TO DEVELOPE A DIALOG INTERFACE TO ROTATE 90d, 180d, 270d, SET AN ARBITRARY OR ENTITY'S ANGLE, OR RESET TO "NORMAL" UCS/DISPLAY ORIENTATION
    2000-01
    Seattle WA USA
    5,859
    Default Re: Modify the color of the UCS icon via LISP?
    I don't think it is possible in Visual LISP.
    100 Club lance.81922's Avatar
    2005-01
    Santa Fe, NM
    176
    I have been looking into this, and can't find a way to access the UCS Icon's properties even in the registry. Clearly it's stored somewhere, but it's not obvious where. It looks like the AutoCAD Object Model makes no reference to the UCS Icon other than on/off/origin etc. This is a puzzlement.
    2000-01
    Seattle WA USA
    5,859
    Quote Originally Posted by lance.81922
    It is probably accessible from ObjectARX, but not Visual LISP.
    126
    Modelspace icon color: (getenv "UcsIconActiveColor")
    Layout icon color: (getenv "UcsIconNonActiveColor")
    Setting colors with SETENV requires a regen for updating. Tested in 2005.
    2005-01
    Santa Fe, NM
    176
    Thank you! Very cool!
    2000-01
    Seattle WA USA
    5,859
    Thanks Stig. I thought that there might be Acad.cfg access to it, but didn't take the time to dig that far.
    2005-01
    Santa Fe, NM
    176
    Here's your code with the UCSIcon embellishment:
    ;;; DISPLAY-ROTATE.LSP
    ;;; Note that this program declares the variables
    ;;; ICONSTATE and UCSICONCOLOR as global variables
    ;;; so that they can be retrieved by DISPLAY-RESTORE
    ;;; to alter UCSICON properties
    ;;; Model Space icon color: (getenv "UcsIconActiveColor")
    ;;; Layout icon color: (getenv "UcsIconNonActiveColor")
    ;;; NOTE: GETENV and SETENV calls are CASE-SENSITIVE!
    (defun c:display-rotate ( / tilemode)
      (setq iconstate (getvar "UCSICON")
    	tilemode  (getvar "TILEMODE")
      (command "UCSICON" "ON")
      (if (= tilemode 1)
    	(setq UCSIconColor (getenv "UcsIconActiveColor"))
    	(setq UCSIconColor (getenv "UcsIconNonActiveColor"))
      (command "_UCS" "n" "z" "90")
      (command "_PLAN" "Current")
      (if (= tilemode 1)
    	(setenv "UcsIconActiveColor" "1")
    	(setenv "UcsIconNonActiveColor" "1")
      (command "_REGEN")
      (princ
    \nUse the command \"DISPLAY-RESTORE\" to return your view settings to normal."
      (princ)
      (setvar "UCSICON" iconstate)
      (command "_UCS" "w")
      (command "_PLAN" "w")
      (if (=(getvar "TILEMODE") 1)
    	(setenv "UcsIconActiveColor" UCSIconColor)
    	(setenv "UcsIconNonActiveColor" UCSIconColor)
      (command "_REGEN")
      (princ
      (princ)
  1. Color wheel icon properties in ribbon
    By mroth3270139 in forum Software
    Last Post: 2010-09-13, 09:26 PM
  2. Modify layers by color
    By Capn in forum AutoLISP
    Last Post: 2008-07-11, 05:39 PM
  3. Icon background color in 2009
    By jpaulsen in forum AutoCAD CUI Menus
    Last Post: 2008-05-20, 03:31 PM
  4. Icon Color in Tool Palettes
    By rgorman in forum AutoCAD General
    Last Post: 2006-11-17, 09:13 PM
