Results 1 to 6 of 6
Thread: Autocad 2000i installation to Windows XP
    2004-06
    St. Louis County
    2
    Default Autocad 2000i installation to Windows XP
    Does anyone have a suggestion as to how to install Autocad 2000i into Windows XP? I loaded Autocad 2000i onto my laptop that originally had Win 98. Do I need a special driver to install it?
    Thank you for your help,
    SAA
    100 Club rclayton's Avatar
    2005-04
    Harrisville, MI
    166
    Default Re: Autocad 2000i installation to Windows XP
    I am not at all sure that XP was out when 200i was released, but Win 2000 was and I believe was the preferred platform for 2000i. With that said, the core kernel of XP is based on the Windows 2000 kernel so there should be no problem installing 200i to Win XP, however compatibility cannot be guaranteed. Any application that ran on Windows 2000 that I have tried worked on Win XP so the install should complete without too much trouble.
    I say, give it a try ... Let me know if you have any particular issues and I will try to help. I don't have a copy of 200i since my company went from R14 to 2002, but R14 ran on XP when I first tried it.
    2005-04
    Harrisville, MI
    166
    Quote Originally Posted by steveazar
    I loaded Autocad 2000i onto my laptop that originally had Win 98....
    SAA
    Did you upgrade your Win98 to XP or did you load XP from scratch? I have had nothing but problems on any system running 98 that was upgraded due to the older drivers in Win98. A fresh install of XP will run much more stably...
    Time Lord Steve_Bennett's Avatar
    2015-12
    far, far, far away...
    4,722
    We ran regular Acad 2k on XP for a while & 2k was always crashing. Then when we upgraded to ADT 2004 & installed it, later we went to uninstall 2k & that screwed up 2004 forcing us to reinstall it. That was really irritating.
    Steve Bennett |BIM Manager
    Taylor Design | Adventures in BIM
    2005-04
    Harrisville, MI
    166
    Quote Originally Posted by Steve_Bennett
    We ran regular Acad 2k on XP for a while .....
    I have been running AC2002 on XP for over a year and had very little trouble with it... by that
    I mean no more or less crashes than on Win2K
    0,0,0 The Origin
    8,569
    Use WinXPs Compatibility Wizard when installing. Tell it to use Win2k. After installation, apply the wizard to the installed acad.exe programme file. That should do it.
    John B
  1. Installation AutoCAD 2010 Windows 7
    By joel.cuny in forum Français - AutoCAD / AutoCAD LT - Général
    Last Post: 2010-02-09, 07:05 AM
  2. AutoCad LT 2000i student version installation issue
    By ronrobl in forum AutoCAD 3D (2006 or below)
    Last Post: 2009-08-17, 05:27 PM
  3. AutoCAD Lt 2000i Student Version Installation Issue
    By ronrobl in forum AutoCAD LT - General
    Last Post: 2009-08-07, 11:41 PM
  4. Windows XP and AutoCAD 2000i
    By axa2001ro in forum AutoCAD General
    Last Post: 2009-06-22, 06:03 PM
  5. Windows XP - Fatal Error during installation of 2000i
    By smartinelli in forum Operating Systems
    Last Post: 2004-12-12, 03:50 PM
