Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: How do draw a line in the "Z" axis?
    All AUGI, all the time cadkiller's Avatar
    2003-09
    Bergenfield, NJ
    697
    Default How do draw a line in the "Z" axis?
    Group;
    This may sound like a silly question; but how do you draw a line in the "Z" axis?
    Everytime I try, it asks me to select a plane to work on.
    In Autocad I can adjust the UCS and can draw in any direction.
    How does Revit work in this regard?
    I'm trying to construct a wire frame diagram, to be able to sweep a profile along a sloping arc.
    2001-12
    Irvine, CA
    7,567
    Default Re: How do draw a line in the "Z" axis?
    Quote Originally Posted by cadkiller
    ...This may sound like a silly question; but how do you draw a line in the "Z" axis?...
    In elevation or section Revit doesn't create a work plane at the cut line of these views. So to sketch lines in these views you must either, place a reference plane first and name it, or pick the face of an object in your view. Doing either will define a work plane (surface) that Revit can use to hold these lines.
    2003-09
    Bergenfield, NJ
    697
    Steve;
    Thanks for the quick reply. I was able to create the line on the "Z" axis; but have a problem moving it and having it snap to other objects I created. I guess the snaps don't work because of the work plane. Is it that you can only snap to a line object that is on the current work plane?
    All AUGI, all the time dpasa's Avatar
    2004-08
    Greece
    637
    I believe you must move the ref plane, not the line
    2003-04
    Chino, CA
    4,756
    You can only work in the x/y of the current plane. You cannot snap to a point that does not fall on that plane.You wont be able to start an arc on that plane, and finish it on another plane.
    Moderator JamesVan's Avatar
    2016-01
    New York, NY
    625
    Try Reference LINES instead of Reference PLANES. They connect point to point instead of relying on a work plane.
    2003-05
    5,153
    But, Reference Lines can only be used inside the Family editor.
    2004-05
    307
    Quote Originally Posted by beegee
    This is another area that Revit need to mimic Inventor in due time I hope.
    Boolean operations outside the family editor would be nice too!
    Same with sweeps/fillet/lofting etc (3DS max is great).
    2003-09
    Bergenfield, NJ
    697
    There should be a toggle that allows for switching the direction between the X, Y & Z axis. This would be useful for wire framing some complex geometry. IMO restricting only working in the X & Y of the current plane is abit of a draw back for a 3D program. I understand that it wouldn't be good to construct an arc like that; but I should be able to snap to lines in other planes.
    PS: Autocad allows for snapping lines like this and ADT has the ability to edit AEC objects in any direction using the Ctrl key. When you select a grip the UCS automatically rotates depending on which grip you select.
    2004-05
    307
    Yes! this is one of the rare cases that Autocad still impresses me
    Besides booleans, and some other stuff he he
  1. Replies: 4
    Last Post: 2014-01-01, 07:58 PM
  2. Replies: 0
    Last Post: 2012-06-06, 11:54 AM
  3. Set Z-axis so it aligns with the "instantaneous" direction of the Spline?
    By Mike Y in forum AutoCAD 3D (2007 and above)
    Last Post: 2007-03-11, 01:17 PM
  4. Numerous "slightly off-axis" warnings
    Last Post: 2006-07-27, 01:31 AM
  5. "y-axis is normalizing" dialog box, what does it mean?
    By cnenninger in forum AutoCAD General
    Last Post: 2006-03-29, 08:11 PM
