Is there any way to get the material maps to transfer along with the model into dwg format for use in Viz?
It appears that any standard brick material from Revit keeps its base color but the 'mapping' does not export.
Thanks
The Captain
Thanks
The Captain
That is because the standard revit brick material is a procedual accurender material that is specific to that application only, it can't be translated to a viz material. If use imaged based materials (jpeg, etc) in revit, they will trnsfer to viz, but you will still have apply uwv mapping.Originally Posted by captainbunsaver
hth,
Z
Chris
SOM | New York
