Thread: Text Tool Scale vs Mtext Scale
    Active Member tomdillenbeck's Avatar
    2004-05
    Dearborn, MI
    52
    Arrow Text Tool Scale vs Mtext Scale
    The Text Tool on the Document > Annotation palette uses a tool called _AECDTLANNOLEADERADD to create MText at the current scale set in the Drawing Window Status Bar.
    However, my coworkers and I like to type "MT" to create our mtext. Unfortunately it does not read the scale from the DIMSCALE or wherever the AECDTLANNOLEADERADD gets the scale.
    Has anyone found a work-around or a keyboard shortcut for implementing MText at the Dimscale?
    2003-03
    Philadelphia, PA
    2,392
    Default Re: Text Tool Scale vs Mtext Scale
    Create a custom LISP routine using the defun name C:MT that reads the current annotation text height and drawing scale, sets the product of the two as the default text height and fires up the MTEXT command.
    2011-05
    926
    By the time you create a workaround, wouldn't it just be easier to use the tool pallette?
    2003-03
    Philadelphia, PA
    2,392
    Unless you wrote it when ADT2004 was current and there was no text tool available.
  1. Option to scale or not scale text according to viewport
    Last Post: 2012-07-27, 05:01 AM
  2. Mtext and Annotation scale
    By mjohnson.88569 in forum AutoCAD General
    Last Post: 2008-11-05, 02:48 PM
  3. Mtext Scale Issues
    By peter.giampa in forum AutoCAD Annotation
    Last Post: 2008-08-07, 06:15 AM
  4. Scale Hatch and Text from Tool Palette
    By bevinbrown in forum AutoCAD Customization
    Last Post: 2006-11-15, 09:52 PM
  5. Scale for text as in "scale for Dim feature
    By arshadmirza786 in forum AutoCAD Wish List
    Last Post: 2004-12-13, 08:07 AM
