So I'm doing this school classroom building, and it started basic...generic 6" walls, etc. I've popped in the windows, doors, got the parapet Trim on, some overhanging canopies, the roof, etc. Then I had swapped out the generic wall type for a compound wall, stucco exterior, gyp board interior, wood stud structure. In fact, the model is getting pretty complete. But then I noticed on the back side of the parapet, i still had Gyp Board, which needs to stop inside the ceiling space, and then be stucco on the inside of the parapet.
Easy, right? Perfect condition for stacked walls. I make a new basic wall type with stucco both sides, and create my stacked wall type. When I select a basic wall in the model, and then go to the Type pull down to replace it with my Stacked Wall, I get errors, stating:
"Switching wall type to Family Curtain Wall. All Dimension References to the side faces of the Wall will be deleted."
and
"Switching element type to Curtain Family. All Wall Sweeps or Reveals hosted by this instance will be deleted."
And then all my reveals and the wall sweep parapet cap go away! But I'm not using a curtain wall at all!!!! What the heck is going on? We must have the abiltity to start generic, and move towards more complex walls as the design develops, including changing Basic to Stacked Walls!
Any ideas?
