Thread: Attribute Extraction Template File
    2005-01
    Massachusetts
    26
    Default Attribute Extraction Template File
    I am using AutoCAD LT 2006 and am trying to extract attributes for some points. I cannot figure out how to create a template file though. Can anybody explain this to me?
    2001-12
    St. Louis
    5,407
    Question Re: Attribute Extraction Template File
    Quote Originally Posted by hydestone2002
    not an lt user but chiming in anyway,
    I haven't created a template manually since using 2002 (painful to say the least).
    going through the attribute extraction wizard, I pick the blocks and set up the options, then on the last page I get a message that says 'if you want to save your settings for future extraction use, click Save Template' button. which creates a filetype .blk.
    Do you get that wizard in LT as well?
    Melanie Stone
    @MistresDorkness
    Technical Editor
    13,656
    Default Re: Attribute Extraction Template File
    Quote Originally Posted by Wanderer
    Hi
    As far as I know, AutoCAD LT 2006 does not come with the EAttExt command ( RE: Attribute Extraction ).
    Have a good one, Mike
    2001-12
    St. Louis
    5,407
    Cool Re: Attribute Extraction Template File
    Quote Originally Posted by Mike.Perry
    Hi
    Gotcha, thanks for confirming my doubt.
    So, sorry, hydestone, will have to wait for a real LT user to chime in.
    Melanie Stone
    @MistresDorkness
    Technical Editor
    I could stop if I wanted to tyshofner's Avatar
    2004-03
    Dallas, Tx
    229
    Nope, no enhanced attribute editor in LT but, you can write a template file. If you have LT you should be able to search the Help for "block attributes". This should bring up the topic "Extract Block Attribute Data". You will get all the info you need from that topic. Don't let it scare you though it just "looks" complicated once you actually create one it will be pretty easy. If you need help just let me know.
    Ty
  1. Creating Attribute Extraction Template File
    By mmalett1649494 in forum AutoCAD LT - General
    Last Post: 2012-08-03, 12:15 PM
  2. Data Extraction Template (.blk) File
    By CADdancer in forum AutoCAD Tables
    Last Post: 2009-06-19, 08:50 PM
  3. Attribute extraction to file
    By lee.johnson in forum AutoLISP
    Last Post: 2008-07-25, 10:59 PM
  4. Attribute extraction to xls file
    Last Post: 2008-07-11, 02:49 PM
  5. Replies: 1
    Last Post: 2006-12-10, 01:35 PM
