david_peterson
Break it up the same way you do now. Or, even more. For example I have a 2 story building. I have a construct for: Footing, below grade walls, above grade concrete walls, foundation walls, basement cmu wall, ground floor framing, ground floor walls, roof framing, high roof framing, existing basement, existing ground floor wall, existing roof framing......
Break it up into an many pieces as you need.
We set up levels for basement, ground floor and roof. So when I need to model stuff, I place my objects in realtion to each level ie z elevation of my footings in -4'-0"
you could also break up exterior walls from interior wall. Assuming your on 2005 or above, the walls should clean up with the x-refs that are being added to each construct to make up your view files.
Hope this helps.
