Thread: Autocad 2006LT plotting problems
    2004-11
    I live in the Yorkshire dales - its asleep, which is the way I like it.
    35
    Default Autocad 2006LT plotting problems
    Not sure if this is the right place to post, so I won`t get upset if this thread gets moved.
    I have just had 2006LT installed and it won`t plot.
    I just keep getting the message saying " unhandled exception violation "
    I suspect our IT section couldn`t fix it.
    Anybody got any ideas ?
    13,656
    Default Re: Autocad 2006LT plotting problems
    Hi
    Does this occur when you issue the Plot command or within the Plot dialog box?
    Have you tried a Repair / Install?
    Have you tried the AutoCAD LT Knowledge Base on the Autodesk web site -
    unhandled exception violation plot returned 5 results.
    Have a good one, Mike
    2004-11
    35
    Thanks Mike
    It looks like Autocad 2006LT doesn`t have the driver for our plotter, so it crashes.
    13,656
    Hi
    Have you tried Plotting via the Windows System Driver for that output device?
    Does the output device support HPGL/2 or similar? If yes, you could try configuring an AutoCAD LT Plot Configuration File (PC3) to output to that format and Plot fom there.
    2004-11
    35
    Tried it Mike - still didn`t work.
    Thanks for the suggestion though.
  1. Replies: 0
    Last Post: 2015-08-07, 04:02 PM
  2. AutoCAD OLE Plotting Problems
    By zach_hill in forum AutoCAD General
    Last Post: 2008-02-21, 12:38 PM
  3. Cui for Adt & autocad 2006LT
    By jcapp in forum ACA General
    Last Post: 2005-12-29, 08:42 PM
  4. Tablet PC usage for AutoCAD 2006LT in school
    By ImmanuelA in forum Education
    Last Post: 2005-12-27, 05:21 AM
  5. Problems Plotting in AutoCAD 2005
    By jaredw in forum AutoCAD Plotting
    Last Post: 2004-11-18, 02:18 AM
