Thread: Split Construction Documents
    I could stop if I wanted to stuntmonkee's Avatar
    2004-03
    Phoenix Arizona
    429
    Default Split Construction Documents
    Seeing if any of you have figured out how to do this yet, or have any good pointers.
    Working on a subdivision with 3 house plans, but they will all share similar information. Let's just talk details for now.
    So I have 3 separate models. And in those models is where the sheets are that pertain strictly to those houses. . .plans, elevations, sections, schedules.
    My hang up comes when I'm trying to figure out the best way to be able to reference a single set of details as opposed to inserting the same detail into all 3 sets of drawings.
    Anyone have any ideas. I feel like there might be some trick way of doing this, but the best way that I can come up with so far is to manually reference information to an outside set of drawings.
    Thanks Stunts
    2002-02
    St. Louis, MO
    4,695
    Default Re: Split Construction Documents
    We do our housing projects all as one file. It is not uncommon for us to have a dozen buildings in one file. It would be nice if there were a better way for coordination.
    2004-03
    Phoenix Arizona
    429
    ouch. I haven't tried, but I can see that causing more problems than it fixes. . . .but would like to hear the benifits.
  1. Mirrored Building Construction Documents
    By darkstknight1523 in forum ACA General
    Last Post: 2010-05-03, 09:59 PM
  2. Use of 3D images in Construction Documents
    By dc.109967 in forum Revit Architecture - General
    Last Post: 2008-08-21, 11:33 AM
  3. Quality Construction Documents
    By paul.meco in forum Revit Architecture - General
    Last Post: 2006-09-15, 05:38 AM
  4. Construction Documents
    By SkiSouth in forum Revit Architecture - General
    Last Post: 2005-10-21, 08:28 PM
