Results 1 to 10 of 12
Thread: Running dimension or baseline dimension?
    2004-07
    179
    Default Running dimension or baseline dimension?
    Good day everyone.
    Could u please tell me if its possible to create running or baseline dimensions in revit as u do in autocad.
    Regards,
    Aliya
    I could stop if I wanted to Shaun v Rooyen's Avatar
    2005-02
    337
    Default Re: Running dimension or baseline dimension?
    Aliya. As with most things in Revit you do it differently to acad. Select all the objects you want to dim first, then set your baseline position.
    2003-04
    Chino, CA
    4,756
    You can:
    1. Place a single dimension, then modify the dimension by clicking Edit Witness line in the Options bar. After clicking Edit Witness line, click the next item in the string to dimension to.
    2. Dimension an entire wall at once. Start the dimension tool, look to the Options Bar, and change the settings as you need to dimension openings, grids, walls, etc.
    3. Dimension running dimensions by clicking. Start Dimension, click first point, then second point, then third, etc until done, then click to set the position of the dimension string.
    Also, dimension spacing can be set in the Dimension Properties, so an overall dimension will 'snap' to a distance away from the running dimension below it.
    I'm waiting for the Factory to figure out "Dimension Everything" with one click!
    Member Chirag Dedhia's Avatar
    2005-05
    Mumbai, India
    37
    What u have mentioned is, i guess, continuous dimensioning. I also, still wonder how the baseline dimensioning works in Revit.
    Any help on this?
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,440
    What is baseline dimensioning?
    Scott D. Brown, AIA
    BECK
    100 Club daniel.hurtubise70031's Avatar
    2004-06
    Montreal, Canada
    153
    Dimension that starts from the same point (baseline)
    Know what i mean ?
    I could stop if I wanted to mmodernc's Avatar
    2004-10
    Cronulla, Sydney
    318
    Often this is how you measure an existing building i.e. run the tape and read off positions of windows doors etc.
    The only way I have been able to do it is to run a stack of dimensions from a common starting point.
    It would be nice to have them starting with a dot then having arrowheads pointing in the running direction all on one witness line.
    Have I missed something?
    2001-12
    Irvine, CA
    7,567
    Personally baseline dimensioning is something you find in fabrication detailing. A steel angle punched for example where it is important that all the holes are the correct distance from one end only for all pieces (to line up when assembled).
    It isn't as relevant or as effective for buildings because of the great distances and numbers of objects involved. It isn't practical to tell a contractor that the window is 85'-6" from the far end of the building when it's only 30'-0" from the near or 4'-0" from the adjacent window?
    Not saying you shouldn't use them...to create them with Revit you need to create separate strings and "stack" them up.
    2004-07
    179
    Thanx,
    Normally Baseline dimensions are done in interior planning So I feel it should be added in revit since its an architectural software and interior is a part of it.
    Regards,
    Aliya
    2004-10
    Cronulla, Sydney
    318
    Ditto
    If you want to set out a buliding accurately you run the tape.
  1. Running Object Snap Lost During Dimension Input
    By cadjockey in forum AutoCAD General
    Last Post: 2012-11-29, 01:16 PM
  2. Replies: 6
    Last Post: 2011-04-25, 07:55 PM
  3. Dimension Running String / indicative crs
    By kurk in forum Revit Architecture - General
    Last Post: 2008-05-28, 05:12 AM
  4. Fire escape path running dimension
    By tomnewsom in forum Revit Architecture - General
    Last Post: 2008-03-27, 02:52 PM
  5. linear dimension style: no leader + position dimension
    By eddy.lermytte in forum Revit Architecture - General
    Last Post: 2006-02-01, 02:04 PM
