Is there any way to set the arrow type for an annotation either by type catalog of globally? PITA to set this up for each family type after importing a bunch.
Aaron, not sure if I understand completely. A little vague (PITA..???). But under settings/annotations/arrowheads is where the global change can take place. By default everthing uses the "arrow 30 degree" so I normaly just change that.
(Edit by SD: PITA: 1. A flat, round, bread like food often used in a form of sandwich making. 2. Acronym for "Pain in the Arse")
If you load a generic annotation with several family types, the arrowhead for its associated leader will be set to "None". Now you have to open the properties of each symbol you place, and set the type of arrow you want to use.
With over 250 keynotes, this can take a while to do. Settings->Annotations-Arrowheads doesn't affect symbol leader settings.
And that is what is called a "PITA"!!!
Right Aaron?
"You're on your own....., Alone!!!"
Enjoy changing your 250 keynotes
