Results 1 to 9 of 9
Thread: Trimming Facia Board
    2003-12
    Southern Ontario
    58
    Default
    I have a simple gable end with 2 roof returns. The gable facias need to be trimmed in length to sit on the roof returns. Any ideas how to do this.?
    Revit Family Guy adegnan's Avatar
    2003-04
    DeForest, WI
    633
    Default Re: Trimming Facia Board
    You probably need to join the two roofs together. Post a jpg so I can confirm you are talking about what I think you are?
    Otherwise jog your main gable back out of the way and have the returns finish off the area. Join the roofs or join the geometry.
    2003-12
    Southern Ontario
    58
    How do you go about posting a jpeg?
    All AUGI, all the time Henry D's Avatar
    2003-05
    Fairfield, Iowa
    669
    When you post a reply there is an "Add an Attachment" option at the bottom of the page. If you select it you can then browse your drive for the file you want to attach.
    2003-12
    Southern Ontario
    58
    I dont know how to save a jpeg from my dwg in revit
    2003-04
    Chino, CA
    4,756
    File>Export>Image will export any view from Revit to a JPG. (or BMP, TIF, TGA)
    2003-12
    Southern Ontario
    58
    This is the jpeg. I tried roof join but got error message.
    2003-04
    DeForest, WI
    633
    I did what you wanted to by using the join geometry tool. Pick the tool, click on the main roof, and click on the return.
    2003-12
    Southern Ontario
    58
    It worked Perfect!
  1. Distribution Board (Panel Board) Symbol
    By schrodingerscat in forum Revit MEP - Families
    Last Post: 2008-10-01, 01:29 AM
  2. Problem with facia sweeps
    By Dave Lewis in forum Revit Architecture - General
    Last Post: 2007-01-19, 09:16 PM
  3. Improvement to Fillet & Chamfer trimming/no trimming options
    Last Post: 2006-07-12, 03:00 PM
  4. Facia behind gutter
    By Bill.Jensen in forum ACA General
    Last Post: 2006-06-23, 12:09 PM
  5. Facia
    By philipnoland in forum Revit Architecture - General
    Last Post: 2006-02-28, 10:48 PM
