I managed to get this technique right in several other low-end packages and I thought I would try in AccuRender, so here it goes:
1. Under the "Rendering" drawer in Revit select "Lighting" and turn the Sun light off.
2. Select the highest level of your project. Select the "Component" option under your "Basics" drawer and load the "M_StudioLight.rfa" into your project (found under Lighting Fixtures).
3. Insert between 10 and 20 of these lights closely grouped together (the closer the better).
4.Setup your camera view and select the "Render" drawer again. Click on "Settings" and change the quality of your raytrace to "Best". Also switch "Soft Shadows" on.
5. Go ahead and Render!
- This technique creates multiple shadows and when the shadows are softened and blended they simulate a shadow with blurred edges.
-To increase the quality of your shadows add more lights and try moving the group of lights closer to the object.
- Unfortunately this technique removes the ability to accurately create Time and Place shadows, i would recommend however doing a benchmark Draft Render using the Date, Time and Place setting for sun to be able to get an idea of where to place your studio lights.
NOTE: this increases your render time tremendously, so only use this for your final render.
The first image is the Sun Shadow render, the second utilizes the technique described above.
