Thread: Paperspace & plotting very slow
    2004-05
    Default Paperspace & plotting very slow
    Anything that involves regeneration to/from paper space or plot preview takes an extraordinarily long time. Any suggestions on how to speed things back up?
    13,657
    Default Re: Paperspace & plotting very slow
    Hi
    See if any of the following helps...
    Technical Document on the Autodesk web site under the Knowledge Base section -
    ID: TS31465 - Plotting is slow from layouts
    ID: TS29697 - Layout viewports with complex linetypes degrade plotting performance
    Forum threads...
    Plotting 2005 how slow is it for you?
    Zoom in PS causes lockup
    Have a good one, Mike
    2005-05
    20
    I've had a similar problem with simply opening new files. It's periodic, but it holds me up for over a minute sometimes...
    2005-01
    185
    audit and purge everything (including the -purge regapps option after purging everything else) do this in the drawing that has the problems and all xrefs attached to it, should fix it up, you may also find a particular block (esp. if it has mtext fields in the block) may be slowing you down.
  1. Modelspace to paperspace transition is really slow?
    By jcgildersleeve159235 in forum AutoCAD Civil 3D - General
    Last Post: 2012-11-06, 02:17 PM
  2. Painfully slow pan and zoom in paperspace
    By craig.65586 in forum AutoCAD General
    Last Post: 2008-10-03, 01:26 AM
  3. Paperspace Plotting
    By smooth shoes in forum AutoCAD General
    Last Post: 2008-04-08, 12:30 AM
  4. Replies: 6
    Last Post: 2006-05-23, 09:40 PM
  5. Slow in Paperspace
    By peter.woodcock in forum AutoCAD General
    Last Post: 2004-11-16, 02:21 PM
