Results 1 to 7 of 7
Thread: Command line Auto-Hide
    Time Lord Steve_Bennett's Avatar
    far, far, far away...
    4,730
    Arrow Command line Auto-Hide
    I would like to have the ability to use the auto-hide function for the command line like in vanilla acad.
    Why couldn't they do the same for ADT? It makes no sense. I understand you still need the command line for some functions, but they could at least have made it the same on verticals. More irritating than anything I suppose.
    Steve Bennett |BIM Manager
    Taylor Design | Adventures in BIM
    2002-07
    34
    Default Re: Command line Auto-Hide
    You can change this behavior in the FixedProfile.aws file. You will find the FixedProfile.aws in "C:\Documents and Settings\<user name>\Application Data\Autodesk\ADT 2006\enu\Support\Profiles"
    Change the "Style" value from "32" to "46". (32 is the value before any changes have been made to the command line)
    'Original' string "<CAdUiPaletteSet ActivePaletteIndex="0" TitleBarLocation="0" AutoRollup="0" Name="Command Line" Style="32" Opacity="100" Visible="1"/>"
    Change to "<CAdUiPaletteSet ActivePaletteIndex="0" TitleBarLocation="0" AutoRollup="0" Name="Command Line" Style="46" Opacity="100" Visible="1"/>"
    Unfortunately this was a nuance that was missed.
    Thanks -
    Chris
    4,730
    Talking Re: Command line Auto-Hide
    This is Great!!!
    Thanks for posting this, as it worked like a charm.
    I will add a note to this, as when I was using MS Word to modify the FixedProfile.aws file, I found 2 text strings that matched the description. One string was towards the middle of FixedProfile.aws & the other was at the very end of it. I don't know if it was critical or not, but I changed the values of both strings to the number you said to use. This produced the desired results I was wishing for.
    One wish list item came early this year!
    Moderator arcadia_x27's Avatar
    2015-10
    The 'Mill,Moncton, NB, Canada
    516
    Will this work for ADT/ABS 2005 as well?
    And in regards to Steve's last post, It does make a difference, I changed just the last instance of the string and nothing happened. Once both were changed it worked.
    4,730
    Quote Originally Posted by arcadia_x27
    YES!!! It does! I just tried it & it worked as expected for ADT2005.
    WoHoo!!
    2009-08
    Akron, Ohio
    5
    Can this work in MEP 2010?.
  1. Hide text in command line when using tool palette commands
    By jpcadconsulting347236 in forum AutoLISP
    Last Post: 2014-10-28, 06:00 PM
  2. 2011: Auto hide constraints
    By jason907238 in forum AutoCAD General
    Last Post: 2010-07-09, 01:00 PM
  3. Animated Auto-hide
    By jspartz in forum NavisWorks - General
    Last Post: 2010-05-19, 11:21 PM
  4. Command Line Auto-Hide
    By Steve_Bennett in forum AMEP Wish List
    Last Post: 2005-06-04, 04:59 AM
  5. SSM Auto-Hide
    By zfoland20 in forum AutoCAD General
    Last Post: 2004-06-30, 09:51 PM
