Results 1 to 7 of 7
Thread: Command line Auto-Hide
    Time Lord Steve_Bennett's Avatar
    2015-12
    far, far, far away...
    4,724
    Arrow Command line Auto-Hide
    I would like to have the ability to use the auto-hide function for the command line like in vanilla acad.
    Why couldn't they do the same for ADT? It makes no sense. I understand you still need the command line for some functions, but they could at least have made it the same on verticals. More irritating than anything I suppose.
    Steve Bennett |BIM Manager
    Taylor Design | Adventures in BIM
    2002-07
    34
    Default Re: Command line Auto-Hide
    You can change this behavior in the FixedProfile.aws file. You will find the FixedProfile.aws in "C:\Documents and Settings\<user name>\Application Data\Autodesk\ADT 2006\enu\Support\Profiles"
    Change the "Style" value from "32" to "46". (32 is the value before any changes have been made to the command line)
    'Original' string "<CAdUiPaletteSet ActivePaletteIndex="0" TitleBarLocation="0" AutoRollup="0" Name="Command Line" Style="32" Opacity="100" Visible="1"/>"
    Change to "<CAdUiPaletteSet ActivePaletteIndex="0" TitleBarLocation="0" AutoRollup="0" Name="Command Line" Style="46" Opacity="100" Visible="1"/>"
    Unfortunately this was a nuance that was missed.
    Thanks -
    Chris
    2015-12
    4,724
    Talking Re: Command line Auto-Hide
    This is Great!!!
    Thanks for posting this, as it worked like a charm.
    I will add a note to this, as when I was using MS Word to modify the FixedProfile.aws file, I found 2 text strings that matched the description. One string was towards the middle of FixedProfile.aws & the other was at the very end of it. I don't know if it was critical or not, but I changed the values of both strings to the number you said to use. This produced the desired results I was wishing for.
    One wish list item came early this year!
    Moderator arcadia_x27's Avatar
    2015-10
    The 'Mill,Moncton, NB, Canada
    516
    Will this work for ADT/ABS 2005 as well?
    And in regards to Steve's last post, It does make a difference, I changed just the last instance of the string and nothing happened. Once both were changed it worked.
    Jason Goodwin
    Using ACA 2012
    2015-12
    4,724
    Quote Originally Posted by arcadia_x27
    YES!!! It does! I just tried it & it worked as expected for ADT2005.
    WoHoo!!
    2009-08
    Akron, Ohio
    5
    Can this work in MEP 2010?.
    2000-01
    Seattle WA USA
    5,859
    Quote Originally Posted by michaelmerda View Post
    Yes, it does.
    R. Robert Bell
    Design Technology Manager
    Stantec
  1. Hide text in command line when using tool palette commands
    By jpcadconsulting347236 in forum AutoLISP
    Last Post: 2014-10-28, 06:00 PM
  2. 2011: Auto hide constraints
    By jason907238 in forum AutoCAD General
    Last Post: 2010-07-09, 01:00 PM
  3. Animated Auto-hide
    By jspartz in forum NavisWorks - General
    Last Post: 2010-05-19, 11:21 PM
  4. Command Line Auto-Hide
    By Steve_Bennett in forum AMEP Wish List
    Last Post: 2005-06-04, 04:59 AM
  5. SSM Auto-Hide
    By zfoland20 in forum AutoCAD General
    Last Post: 2004-06-30, 09:51 PM
