Cheers Fedor,
Just thought there might have been some additonal pdf's or something. It is a largely self documenting the API. Getting incorrect behaviour though.
I've rewritten the StructSample1CS example in python. What's confusing me is
if(elem.get_Parameter(Autodesk.Revit.Parameters.BuiltInParameter.WALL_HEIGHT_TYPE) != null && elem.get_Parameter(Autodesk.Revit.Parameters.BuiltInParameter.WALL_BASE_CONSTRAINT) != null)
should only add a wall with a constrained wall height and bottom constrained to a level. Correct?. Yet with the C# or python version it doesn't matter what the wall height is set to. It still adds the wall.
At least the python script performs the same as the C# versionl
Guy
