Thread: Trim board at the top of exterior residential siding wall
    All AUGI, all the time christo4robin's Avatar
    2003-05
    Boulder, Colorado
    681
    Default
    Anybody have a slick way of doing a trim board at the eave/wall intersection of a residential house? I attempted to use an integral wall sweep, hoping it would follow the slope of the gable end, and the sweep wouldn't "take."
    I've just been using in-place generic families to date. I'm hoping there is a better way.
    Cheers!
    AUGI Addict christopher.zoog51272's Avatar
    2003-04
    Cinnaminson, NJ / NYC
    1,096
    Default Re: Trim board at the top of exterior residential siding wall
    Quote Originally Posted by 4christo4
    Cheers!
    are you talking about rake trim? or a gable end soffit return?
    Anyway here is a file that shows how I do it. and here is an exerpt from my au class:
    Tip #14 Use the roof fascia tool to create additional rake trim
    Select an appropriate profile.
    Pick the gable end of the roof, then
    Set the horizontal offset to “-(depth of overhang)”.
    You also change the miter option to suit different conditions.
    Tip #13 Use a roof soffit to create “pork chops” and other gable end conditions
    You can create various gable end conditions with the roof soffit and fascia tools.
    To create a “pork chop” use the roof soffit tool and the pick roofs, then pick walls option.
    Use the join geometry tool to clean-up the soffit to rake join.
    Chris
    SOM | New York
  1. Does anyone have a batten board siding pat file?
    By Kroke in forum Revit Architecture - General
    Last Post: 2023-09-11, 04:55 PM
  2. lap board siding
    By frank.richarz in forum Its all in the Details
    Last Post: 2010-10-07, 01:41 PM
  3. Barn Siding - Board & Batten
    By gwnelson in forum Revit Architecture - General
    Last Post: 2009-03-19, 09:34 PM
  4. exterior siding below the bottom plate.
    By ray salmon in forum Revit Architecture - General
    Last Post: 2008-09-09, 09:24 PM
  5. Trim in siding wall
    By Carlos GT in forum Revit Architecture - General
    Last Post: 2006-04-06, 05:04 PM
