Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Is Revit the right move??
    2005-06
    Default Is Revit the right move??
    Our firm needs to upgrade our current version of AutoCAD. We need to decide if we want to go with AutoCAD 2006 or Revit 8. I am trying to find good or bad responses if Revit is the way to go. What are the pros and cons in moving to Revit? We have used Desktop in the past but found that it was not what we really needed. We never used Desktop the way it was intended to be used. I am not sure if that was caused by a lack of training.
    I am sure if we go with AutoCAD 2006 we will not have any problems. If we go with Revit will we be happy or will we wast the money and go back to AutoCAD? How does Revit work with consultants that only use AutoCAD?
    If everyone can give me their opinion of Revit that would be very helpful.
    Rob
    I could stop if I wanted to Shaun v Rooyen's Avatar
    2005-02
    337
    Default Re: Is Revit the right move??
    Rob we made the switch 2 years ago, and have never looked back. check this thread I have just posted.
    http://forums.augi.com/showthread.php?t=20705
    2003-04
    Scotland
    1,577
    Go for "Revit Series" that way you get both Revit and Autocad.... costs a tiny bit more. You can get good deals on upgrading Autocad to Revit series, we did this and got both of them for about £500 (depends on your current version though)
    Posting here - I suspect you are going to be told it is the right move! - which it is!!.... Revit series makes the change less "cold turkey" though.
    100 Club Mark Vorstenbosch's Avatar
    2005-03
    155
    Smile Re: Is Revit the right move??
    Hi Rob
    I have been working with Revit for the last 9 months and I can not believe any one would like to work with any other Cad software.
    Revit works.
    2003-01
    Yulee, FL
    184
    I'm a one man build/design operation so you know. I used Architectural Desktop for years. Moved over to Revit about 3 months ago. After an initial learning curve (still much to learn but enough to get some CD's out and much much shorter than ADT) I think Revit is a marvelous program with every possibility of being brilliant. And with Martin, yes you will get a positive response here. People love it .... really.
    Bill Maddox
    AUGI Addict iru69's Avatar
    2004-10
    usa
    1,591
    You only have to use Revit for a few days to see what the big deal is about. I used AutoCAD for ten years, and it worked well for what it does - but now I just feel sorry for architects still stuck with it.
    Download the Revit trial version, go through the tutorial (you've got to put a little work into this yourself, right? ).
    I'm sure you'll get some responses on this thread, but if you search the forum (the search tool is your friend), you'll find a couple of dozen threads on this subject.
    Have a look through http://forums.augi.com/showthread.php?t=12780 put together by BillyGrey.
    Edit: fixed the link...
    I could stop if I wanted to cosmickingpin's Avatar
    2004-05
    North of the 49th
    476
    Nobody uses Architectural Desktop (a 3D BIM solution) the way it is "intended". No matter how good the training, at best it is good for 2d cad on steroids. Even proponents of ADT are forced to admit that revit delivers what it promises and with a highly user friendly interface. I have found that one of the key factors of a firm's sucess with revit is highly dependent on the culture of the Firm. Firms that have a high commitment to adding value to their services, are commited to using and understanding new technology, have personnel committed to expanding their skill set (no matter what software they happen to be using), committed to finding ways to do more in less time and make more money, then Revit is exactly what you want. I would try the free revit for 30 days, do the tutortials, have a free Webcast, and expose your personnel and spend no money doing so, and at the end of 30 days you would be able to make an informed choice. Try to identify key personnel who would be most involved in training and education, get them as much exposure and them have a sit down when you think you have enough data to make a choice.
    In terms of working with consultants, you have a ton of options. A site you will want to spend some time on is:
    http://usa.autodesk.com/adsk/servlet...112&id=3782406
    On the Autodesk website look up the White Papers under Revit there you will find some critical topics like revit's relationship to CAD and studies on firms who make the revit transition. Attached is a copy of the paper that deal with your question specifically.
    Lastly, keep in touch around here and let us know what you decide and if you have any specific questions, people tend to be very generous and if you lurk around you will see what a treasure this community is if you do decide to make the Revit choice.
    Quote Originally Posted by rdy
    Rob
    AUGI Addict PeterJ's Avatar
    2003-04
    London, UK
    1,948
    Some of the really big players are now starting to get into Revit quite seriously. I hear that one major international practice (in excess of 150 architects and £39M fees last year in their UK offices and something in excess of 1,000 architects worldwide so I understand) has taken a board level decision to use Revit based on product maturity and a simple business case. I think that people like that move slowly and are unlikely to make the decision without very serious consideration so you can bet that it's right for them.
    Pete
    Active Member cstarr's Avatar
    2005-02
    65
    PeterJ,
    What firm is that? If you don't mind...
    2003-04
    Chino, CA
    4,756
    Hmmmm...if Only we Knew...
    Scott D Davis
    Sr AEC Technical Specialist
    Autodesk, Inc.
    http://about.me/scottddavis
  1. Time to Move Civil 3D to Revit
    Last Post: 2014-04-22, 02:24 PM
  2. Problem with Revit MEP and the move command and using contrain
    By Ken.drewnowski in forum Revit MEP - General
    Last Post: 2009-06-03, 08:38 PM
  3. Move Revit model to match other disciplines
    By ParagonChris in forum Revit Architecture - General
    Last Post: 2008-08-20, 07:56 AM
  4. Move from AutoCAD to Revit
    By kwong in forum Revit Architecture - General
    Last Post: 2005-02-11, 02:19 PM
  5. Why should I move to REVIT?
    By dpet in forum Revit Architecture - General
    Last Post: 2004-06-29, 07:26 PM
