Results 1 to 6 of 6
Thread: System Variable to control text stacking or not stacking
    100 Club jhohman's Avatar
    2003-08
    Spring Hill, Florida
    195
    Default System Variable to control text stacking or not stacking
    I would like to know the system vairable that sets whether or not fractions are stacked for Autocad. I have a consultant that set his autocad to stack all fractions but the are issues because I do not want any fractions to stack. I searched forums but have not been able to find what system variable controls it. Thank you in advance for all your help. Or if someone has a list of all autocad system variables, I can try to locate it myself. Thanks again.
    2000-01
    Seattle WA USA
    5,859
    Default Re: System Variable to control text stacking or not stacking
    There isn't a system variable. It is stored in the registry under the MText node (HKCU).
    2003-08
    195
    2
    I found how to change it if you had accidentally specified "Do not ask".....
    initiate the MTEXT command and make a boundary window for text anywhere, type a fraction, after it autostacks, highlight the stacked fraction and right click, select properties which is right below unstack in the right click menu, once the properties come up, select the autostack button and there you can specify which behavior you prefer. Hopefully this helps out someone somewhere.
    Marv- Past AUGI President Marv Muston's Avatar
    2000-10
    Orlando, Florida
    230
    Unhappy Re: System Variable to control text stacking or not stacking
    Hi guys.
    How could I find all the stacked fractions in a drawing and replace them with horizontal unstacked all at the same time (like with find and replace)?
    Thanks
    Marv
    AUGI Addict sinc's Avatar
    2004-02
    Colorado
    1,986
    Quote Originally Posted by jhohman
    To add a little bit, you may also do something where you turn off autostacking, and also select "Do not ask..." in the dialog.
    In that case, you can force the creation of a stacked fraction. Type your fraction in the MTEXT editor, for example "1/2". Then select that text, right-click, and select "Stack". This should create a stacked fraction. Now you can select the stacked fraction, right-click and select "Stack Properties". In the dialog box, click on the "Autostack..." button and change the properties as desired.
    This is what's known as "super user-friendly design"...
    2004-02
    Colorado
    1,986
    Quote Originally Posted by marvcad
    Hi guys.
    A custom Lisp?
  1. 2012: Fraction Stacking Control
    By jason.magon in forum AutoCAD General
    Last Post: 2013-07-26, 01:04 PM
  2. Stacking Text in Inventor 2008???
    By theron.j.bliss in forum Inventor - General
    Last Post: 2008-07-23, 07:59 PM
  3. STACKING PALETTES
    By randyspear in forum AutoCAD Civil 3D - General
    Last Post: 2008-05-28, 02:28 PM
  4. Stacking Text in Dimensions
    By JONB.102117 in forum Revit Architecture - General
    Last Post: 2008-04-04, 05:40 PM
  5. Stacking alternate dimensions
    By robert.1.hall72202 in forum AutoCAD Tips & Tricks
    Last Post: 2006-08-07, 05:21 PM
