Results 1 to 6 of 6
Thread: Notch detail
    2004-07
    Detroit Michigan
    2,508
    Default Notch detail
    Is there a way, via lisp, to create the following notch detail????
    The lines are drawn in as shown and then the radii added.
    The angles of the 2 lines vary across drawings.
    2004-07
    Detroit Michigan
    2,508
    Default Re: Notch detail
    didn't see this in the new posts so I am trying to bump it up
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,172
    Quote Originally Posted by rhall.72202
    I am positive this will not work in all instances, but it is a start. I do not know all of your parameters or how your entities are drawn.
    This program assumes the two lines are "LINE" entities. No error checking is provided.
    (defun C:TEST (/ NOTCH:ASC NOTCH:DTR BPNT BRAD INTPICK INTPICK1 INTPICK2 L1 L1-2INT L1ANG L1ANG90 L1E L1S L2 L2ANG L2ANG90 L2E L2S L3 L3-4INT L3E L3S L4E L4S LPNT LRAD TEMP1)
      (defun NOTCH:DTR (A) (* pi (/ A 180.0)))
    ;;; utility to convert decimal degrees to radians
      (defun NOTCH:ASC (ELEMENT ENTITY /)
    ;;; retrieve assoc data from entity
        (cdr (assoc ELEMENT ENTITY))
      (defun MAKEARC (PNT RAD START END / ECODES)
        (setq ECODES (list (cons 0 "ARC")
    		       (cons 8 (getvar "clayer"))
    		       (cons 10 PNT)
    		       (cons 40 RAD)
    		       (cons 50 START)
    		       (cons 51 END)
        (entmake ECODES)
      (setq	L1     (entget (car (entsel "\nSelect Line 1: ")))
    	L2     (entget (car (entsel "\nSelect Line 2: ")))
    	INTPick (getpoint "\nPick point in interior of angle: "))
      (if (not lrad) ; set little radius if not already set
        (setq lrad 0.125))
      (if (not brad) ; set big radius if not already set
        (setq brad 0.5))
      (setq	L1S (cdr (assoc 10 L1)) ; get line 1 start point
    	L1E (cdr (assoc 11 L1)) ; get line 1 end point
    	L2S (cdr (assoc 10 L2)) ; get line 2 start point
    	L2E (cdr (assoc 11 L2)) ; get line 2 end point
      (setq L1-2INT (inters L1S L1E L2S L2E NIL)) ; get line intersection point
      (setq	L1ANG	(angle L1S L1E) ; get line angles
    	L2ANG	(angle L2S L2E)
    	L1ANG90	(- L1ANG (DTR 90.0)) ; get temporary perpendicular angles
    	L2ANG90	(+ L2ANG (DTR 90.0))
      (setq	INTPICK1 (inters L1S L1E INTPICK (polar INTPICK L1ANG90 1.0) NIL) ; get interior angle intersection points
    	INTPICK2 (inters L2S L2E INTPICK (polar INTPICK L2ANG90 1.0) NIL)
      (if (/= (angle INTPICK1 L1-2INT) L1ANG) ; verify line1 angle
        (setq TEMP1	L1S
    	  L1S L1E
    	  L1E TEMP1
    	  temp1 nil
      (if (/= (angle INTPICK2 L1-2INT) L2ANG) ; verify line2 angle
        (setq TEMP1	L2S
    	  L2S L2E
    	  L2E TEMP1
    	  temp1 nil
      (setq	L1ANG90	(angle INTPICK1 INTPICK) ; get perpendicular angles
    	L2ANG90	(angle INTPICK INTPICK2)
      (setq	L3S	(polar L1S L1ANG90 LRAD) ; get temp line 3 start
    	L3E	(polar L1E L1ANG90 LRAD) ; get temp line 3 end
    	lpnt	(inters L2S L2E L3S L3E NIL) ; get little arc radius
      (setq	L3s (polar LpNT (+ L1ANG90 (dtr 180.0)) LRAD)
    	L3E LpNT
      ;(command "line" l3s l3e "")
      (setq	L4S	(polar L2S L2ANG90 BRAD)
    	L4E	(polar L2E L2ANG90 BRAD)
    	L3-4INT	(inters L3S L3E L4S L4E NIL)
      (entdel (asc -1 l1)) ; delete original line 1
      (entdel (asc -1 l2)) ; delete original line 2
      (entmake (subst (cons 11 l3s)(assoc 11 l1) l1)) ; make new line 1
      (setq l3s (polar lpnt l2ang lrad) ; new start point for line 3
    	l3e l2e) ; new end point for line 3
      (setq l3 (subst (cons 10 l3s)(assoc 10 l2) l2) ; line 3
    	l3 (subst (cons 11 l3e)(assoc 11 l3) l3))
      (setq	BPNT ; radius point of big arc
    	 (polar	(polar
    		  lpnt
    		  (- L2ANG (dtr 180.0))
    		  (* (+ BRAD LRAD) (cos (ASIN (/ BRAD (+ BRAD LRAD)))))
    		L2ANG90
    		BRAD
      (setq l2 (subst (cons 11 (inters l2s l2e bpnt (polar bpnt l2ang90 1.0) nil))(assoc 11 l2)l2) ; modify line 2
    	l2 (subst (cons 10 l2s)(assoc 10 l2)l2))
      (entmake l2) ; make new line 2
      (entmake l3) ; make new line 3
      (MAKEARC BPNT
    	   BRAD
    	   (angle BPNT lpnt)
    	   (angle BPNT
    		  (inters BPNT (polar BPNT L2ANG90 1.0) L2S L2E NIL)
      (MAKEARC LPNT
    	   LRAD
    	   (angle LPNT BPNT)
    	   (angle LPNT
    		  (inters LPNT (polar LPNT L1ANG90 1.0) L1S L1E NIL)
    (defun ASIN (X /)
      ;;arcsine= arctan(X/Sqrt(1.0-(X^2)))
      (cond	((= X 1) (setq R (/ pi 2)))
    	((= X -1) (setq R (/ (* pi -1) 2)))
    	(t (setq R (atan (/ X (sqrt (- 1.0 (expt X 2)))))))
      ) ;_ end of cond
    ) ;_ end of defun
    2004-07
    Detroit Michigan
    2,508
    I tried your routine and I am getting "error no function definition: dtr".
    2002-01
    jUSt Here (a lot)
    9,172
    In my code change the following line
    to read
    (defun DTR (A) (* pi (/ A 180.0)))
    sorry
    2004-07
    Detroit Michigan
    2,508
    That works great if the geometry of edge one heads towards the vertex and edge 2 heads away from the vertex. Any geometry that doesn't meet that condition will not work.
    Still an excellent routine, as I can simply fix the line directions.
    Can I throw a kink in there???? How about doing similar with an arc and a line?
  1. Can't Notch or Trim
    By kikky in forum Inventor - General
    Last Post: 2008-10-21, 12:39 PM
  2. Foundation Wall Notch
    By sroy in forum ACA General
    Last Post: 2005-09-19, 07:43 PM
  3. Notch in Wall
    By kwong in forum Revit Architecture - General
    Last Post: 2005-07-22, 01:22 AM
  4. Create This Notch
    By robert.1.hall72202 in forum AutoCAD General
    Last Post: 2005-03-02, 09:53 PM
  5. Rafter notch?
    By gjburkett in forum Revit Architecture - General
    Last Post: 2005-01-07, 10:37 PM
