Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Brick Jack Arches and Arches
    All AUGI, all the time BCrouse's Avatar
    2003-04
    Bethlehem, PA
    980
    Lightbulb Brick Jack Arches and Arches
    Here is a challenge for any of you Lisp Kings. Does anyone have a lisp routine that can create Brick Jack Arch and Arch. The lisp should be able to create these with insertion pt bottom middle. The lisp should also create (4c or 3c) Brick Jack Arches and Arches. they should have the option for a Keystone. The Keystone should be 1 course taller than the 4c or 3c. When the Block is created, it could send the block into a file of you choice. If you have any questions please ask.
    Thanks
    2003-04
    Bethlehem, PA
    980
    Default Re: Brick Jack Arches and Arches
    Would you want to pick one corner of the window / door and to the other corner of the wimdow / door? Are you aware that when you create the 4c JackArches and Arches. The ends need to match? What is the scew of the ends of the Jack Arches?
    Thank you,
    Brad
    Member dkh007.66346's Avatar
    2004-03
    Dallas, TX
    42
    I love a good challenge. But I guess being Monday morning, I'm a little slow. Could you post a screen shot of what you are looking for in the final version?
    2003-04
    Bethlehem, PA
    980
    Here you go. I hope that this help for the Jack Arches..
    Thank you,
    2003-04
    Bethlehem, PA
    980
    Thumbs up Re: Brick Jack Arches and Arches
    Quote Originally Posted by bnc_designs
    Thank you,
    Hopefully the example that you put up will help tackle this task.
    Brad
    2003-04
    Bethlehem, PA
    980
    Exclamation Re: Brick Jack Arches and Arches
    Quote Originally Posted by BCrouse
    Brad
    I hope that it helps. I hope that I did not ask for something that was too difficult for someone to create.
    Thanks
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,099
    Thanks
    Can you explain what you are trying to accomplish? I am not familiar with architectural drafting and therefore do not always understand the terminology. Are these to be arcs? or lines? Are the internal lines supposed to represent bricks? What are the controlling dimensions?
    Just a few questions I was wondering.
    AUGI Addict fixo's Avatar
    2005-05
    Pietari, Venäjä
    1,269
    See if this works for you. Edit if you like.
    Thank you
    2003-04
    Bethlehem, PA
    980
    Smile Re: Brick Jack Arches and Arches
    Quote Originally Posted by fixo
    Thank you
    Thank you your help. I am not that experience in modifing lisp routines. Could these 2 routines be put in to 1, so I could have a choice to choose from? Could it have the option to add a Keystone. Also the 4c height is 10 3/4" tall with the Keystone extending 2 5/8" above that. The 3c is correct.
    This is for Richard.
    3c (3 courses tall)
    4c (3 courses tall)
    Brick Arches are curved
    Brick Jack Arches are straight.
    Thank you,
    Brad
    2005-05
    Pietari, Venäjä
    1,269
    Apologies it's my mistake
    Some question...
    1.Is there will be a precise quantity of bricks along the length of wall to the right and to the left of keystone or it is arbitrary?
    2. I'm worked all my life as crane-mechanic and AutoLisp there is my of hobby
    and architecture there is a problem for me therefore it is needs
    much more information to me:
    If we arch there is curve then considerably more complex necessary use method ActiveX. This will engage more than time especially if arch is with a variable radius as, for instance, parabola. I learned never in the college therefore I badly understand mathematics and moreover I never learned English
    It is need 2 or 3 days to write this program
    Could you post me your final drawing on my e-mail: fixo@yandex.ru if you be
    able as the file .dwg in the version of A2000 or A2005?
    Thanks
  1. Elliptical Arches
    By Wish List System in forum ACA Wish List
    Last Post: 2013-11-15, 08:51 AM
  2. Brick arches
    By sultarc in forum Revit Architecture - General
    Last Post: 2005-12-06, 04:24 PM
  3. Brick Arches
    By BCrouse in forum ACA Wish List
    Last Post: 2005-10-13, 06:55 PM
  4. Mouldings on Exterior Arches
    By pwmsmith in forum Revit Architecture - Families
    Last Post: 2005-02-15, 12:10 PM
  5. Brick Arches and Jack Arches
    Last Post: 2004-06-03, 09:51 PM
