Thread: Separating Wall into Bearing & Non Bearing
    2002-12
    695
    Default Separating Wall into Bearing & Non Bearing
    Is it possible to make a composite wall that can be broken into "bearing and non bearing" components. I have a 8" CMU wall that is "load bearing" with EIFS and a lower 4" face brick. I do not want the EIFS nor the brick to display in my structural views. However I need to maintain the composite wall for my architectural views.
    Do I have to create separate walls i.e. CMU wall and then an EIFS wall with a brick sweep
    to achieve this.
    Regards
    Dick Barath
    2002-02
    St. Louis, MO
    4,695
    Default Re: Separating Wall into Bearing & Non Bearing
    ...not as one wall
    2002-12
    695
    Thanks Aaron - will pursue from another angle then.
  1. Bearing / Non-Bearing Parameter
    By cek in forum Revit Architecture - General
    Last Post: 2009-05-28, 06:31 PM
  2. bearing/non-bearing wall cleanup
    By vanderloo5 in forum Revit Architecture - General
    Last Post: 2009-03-16, 03:05 PM
  3. Bearing / Non-bearing Wall - View differences
    By abink in forum Revit Architecture - General
    Last Post: 2008-06-12, 12:43 PM
  4. Bearing Walls Shaded, Non-Bearing Not...Please.
    By r.grandmaison in forum Revit Structure - General
    Last Post: 2008-02-05, 11:51 PM
  5. Walls - Structural Usage : Bearing and Non-bearing
    By rmejia in forum Revit Architecture - General
    Last Post: 2006-11-28, 05:35 PM
