Thread: ROTATE PARALLEL
    2002-02
    30
    Default ROTATE PARALLEL
    Is there a simple lisp that would rotate text parallel to a polyline? If so what would it be?
    Larry
    AUGI Addict sinc's Avatar
    2004-02
    Colorado
    1,986
    Default Re: ROTATE PARALLEL
    That question doesn't mean anything. Polylines can curve.
    If you want to rotate text to align with THE TANGENT OF A POINT on a polyline, you can do THAT. There's no built-in routine to do it (I don't think), but you can write one. The vlax-curve-getFirstDeriv function will return the direction vector of the polyline at any given point. Simply convert the direction vector into an angle, and voila.
    All AUGI, all the time bbapties's Avatar
    2003-12
    Palm Harbor, FL
    537
    if you have express tools...
    try the command "torient"
    2005-05
    IL
    101
    Quote Originally Posted by engineering.28250
    Larry
    Here's a button I use to create text parallel to a line or polyline, you pick a point on a line, enter text height then click a second point along the same line and then enter your text. You could probably modify it to do what you're looking for.
    ^C^C(setq a (getpoint "Insertion point: "));\text;J;BC;!a;\'cal;ang(a,nea);\\
    Good luck,
    Mike
    Last edited by Fillet Radius Zero; 2005-06-13 at 05:57 PM. Reason: wanted to subscribe to this forum
  1. Rotate Project North does not rotate the Design Options
    By weston in forum Revit Architecture - General
    Last Post: 2009-11-05, 05:22 PM
  2. join rotate block at base point + rotate atribute??
    By killerdemaster in forum AutoLISP
    Last Post: 2008-01-14, 05:10 PM
  3. Can't rotate crop regions to rotate view
    By Wes Macaulay in forum Revit Architecture - General
    Last Post: 2005-02-07, 04:46 PM
  4. Add Attribute Rotate in ROTATE command
    By arshadmirza786 in forum AutoCAD Wish List
    Last Post: 2005-01-12, 09:40 AM
  5. making a 'non-parallel to ucs' object parallel
    By KevinBarnett in forum VBA/COM Interop
    Last Post: 2004-11-12, 01:21 PM
