Thread: ADT 2006 Training
    100 Club pdavis's Avatar
    2005-01
    Tampa, Fl
    188
    Default ADT 2006 Training
    Does anyone have any suggestions for training options for ADT 2006 with an emphasis on strutural?
    Thanks
    2005-06
    LA California
    26
    Default Re: ADT 2006 Training
    All the changes to the Blocks like the Dynamic Blocks, There is so many things that you can do with the Dynamic Blocks. AutoCAD also has the wood blocks to toggle from 2x4 to 2x8 and so on. There is also the steel shape that is now available. Where a lot of firms were buying outside add In's to be able to do this.
    Also the ability to set a block so that it can't be exploded. If you are a structural guy and share plans with other disciplines sometimes your columns and such get exploded so that other items will fit better. As you know this will not work in the real world. Another add is the preview of blocks in the insert command. There is so many items that have helped with this new release.
    All AUGI, all the time tc3dcad60731's Avatar
    2003-10
    Charleston, SC
    575
    I have read the book on ADT (prior release) from Paul Abin and found it to be a great program. However, when considering to upgrade I was told to go to Revit so I have not used ADT at all. I would agree though with the dynamic block input from above. I used to use MDT and I had a part library that was table driven per needs with holes, cut-outs, etc because I was doing one of a kind structural modeling and it was easy to manipulate.
  1. ED35-2: Super Glue Training - AutoCAD 2006
    By Autodesk University in forum Education
    Last Post: 2013-04-17, 04:12 AM
  2. Searching for Archdesktop 2006 training DVDs
    By bakerm in forum Training
    Last Post: 2006-09-19, 08:56 PM
  3. ABS 2006 Training
    By brainalien in forum AMEP General
    Last Post: 2006-02-28, 04:56 PM
  4. Migrating 2002 to 2006/ Getting Training for it.
    By denrich71 in forum AutoCAD General
    Last Post: 2006-02-01, 12:46 PM
