I have the following Selection Set code. It works great on 3 out of 4 computers. 2 of these computers are identical, but one of these is the one that is giving me the problems. It is not finding the items (some of the time) giving a selection set error. When it does decide to start working, it does not have any problems. I can and have made some changes so that the user does not see a error pop up, it just does not work. This is not what I am trying to do. The items (blocks) are in the drawing and I want to select them.
Is there something that I need to set on that computer or something that I need to add to my code?
Thanks in advance,
Jason
(the CreateSelectionSet function is the one that is causing the error)
Public Function pullBlockValue(BlockName As String, Field As String) As String
Dim ssetObj As AcadSelectionSet
Dim I As Integer, ii As Integer
Dim myAttribute
' Create the selection set
Set ssetObj = pullBlocks(BlockName)
If ssetObj.Count > 0 Then
'the block is used in the drawing
myAttribute = ssetObj.Item(0).GetAttributes
For ii = 0 To UBound(myAttribute)
If myAttribute(ii).TagString = Field Or _
myAttribute(ii).TagString = UCase(Field) Then
pullBlockValue = myAttribute(ii).TextString
End If
Next
End If
End Function
Public Function pullBlocks(BlockName As String) As AcadSelectionSet
Dim myAttribute
Dim fType(0 To 1) As Integer
Dim fData(0 To 1) As Variant
Set pullBlocks = CreateSelectionSet()
If pullBlocks.Count = 0 Then Exit Function
fType(0) = 0
fData(0) = "INSERT"
fType(1) = 2
fData(1) = BlockName
pullBlocks.Clear
pullBlocks.Select acSelectionSetAll, , , fType, fData
If pullBlocks.Count = 0 And _
BlockName = "TITLE_BLOCK" Then
Set pullBlocks = pullBlocks("tblock_blk")
End If
End Function
Public Function CreateSelectionSet(Optional ssName As String = "ss") As AcadSelectionSet
Dim ss As AcadSelectionSet, I As Integer
On Error Resume Next
Set ss = ThisDrawing.SelectionSets(ssName)
If Err Then Set ss = ThisDrawing.SelectionSets.Add(ssName)
ss.Clear
Set CreateSelectionSet = ss
End Function
