Thread: Save in AutoCAD 2005 (2004 format), won't open in AutoCAD 2004
    2005-06
    2
    Default Save in AutoCAD 2005 (2004 format), won't open in AutoCAD 2004
    Howdy all,
    This may be an easy one for you...I save my drawing as a 2004 Autocad fornat from my 2005 and it wont open in 2004.
    Any thought? thx
    All AUGI, all the time bbapties's Avatar
    2003-12
    Palm Harbor, FL
    537
    Default Re: Save in AutoCAD 2005 (2004 format), won't open in AutoCAD 2004
    What is the error that you are getting when trying to open?
    0,0,0 The Origin
    8,570
    Quote Originally Posted by garryh
    Howdy all,
    Any thought? thx
    Are you using one the vertical applications?
    A2004, 2005 and 2006 all use the same file format so that should not be the issue.
    2004-07
    Detroit Michigan
    2,508
    I have noticed instances where AutoCad isn't actually saving in the lower format even though you ask for a certain file version. I think it is a bug with AutoCad.
    2001-12
    St. Louis
    5,421
    Red face Re: Save in AutoCAD 2005 (2004 format), won't open in AutoCAD 2004
    Quote Originally Posted by rhall.72202
    in some cases you'll have a file with an x-ref, and the file is saved down, but, the x-ref isn't?
    others, you might do a ref-edit, or a saveas with sheet sets, and they'll save to the current version rather than what you have specified as your 'save as' version...
    but, as someone already mentioned... 2004,05,06 all have same file format...
    Melanie Stone
    @MistresDorkness
    Technical Editor
  1. Replies: 10
    Last Post: 2009-01-02, 07:52 PM
  2. AutoCAD 2007 and 2008 unable to open a DWG file saved in 2004 format
    By Neo_Richard_Blake in forum AutoCAD General
    Last Post: 2007-07-09, 08:50 PM
  3. AutoCAD 2007 - SaveAs 2004 format.
    By b_v_mc in forum AutoCAD General
    Last Post: 2006-06-01, 05:08 PM
  4. Export to AutoCAD 2004 Format Error
    By rick.rivera in forum ACA General
    Last Post: 2006-04-25, 01:01 PM
  5. Replies: 1
    Last Post: 2004-12-14, 09:41 AM
