What is the equivalent AutoCAD command for the microstation command “rotate view element”?
Are you trying to rotate certian entities, or the view?Originally Posted by dmetcal1
Please note I have moved this post to the forum as I believe it is better served here.
Thanks
Not sure if this is what you want, but have you tried the UCS (User Coordinate System) command?
I'm trying to rotate the view so that north is not at the top of the screen, but at some given angle.
Check out the Dview command with the twist option.
Thanks, the dview with a twist worked.
I'm a long time microstation user forced to convert to autocad by company edict.
Welcome to the light side of the force
(hears a choir of angels)Originally Posted by dmetcal1
...and the heavens rejoice with each convert.
