It's not working. Anybody had the same problem and knows how to solve it?
--Thanks.
--Thanks.
mvillamorel-
Please note I've moved your question to this forum as I believe it will get a better response here.
ADT Forum Moderator
I've experienced problems when the "Read Only" does not get changed to "Allow Reverse Lookup". Make sure this option is changed in your table to allow reverse lookup. It seemed to help me. Good Luck.Originally Posted by mvillamorel
"They said some guy arrested for murder in Las Vegas had 'a history of questionable actions.' Can you imagine if we were all held to that standard?" -G.C.
Hi
For starters have a browse of the following threads (and any associated links within) -
Trouble with Lookup actions
Lookups in dynamic blocks
HELP WITH THE "look-up" ACTION
Have a good one, Mike
You might want to also try deleting the lookup table and re-creating the table all over again. I've experienced that some times you need to just start all over again.
If you could post the block we'll be able to help you out a little more.
The Dynamic Block Lookup table does not work with the ADT 2006..but if you load ADT 2006 as just plain autocad, the lookup feature table will work. This is a bug.
