Thread: Please HELP: how to modify a TOLERANCE entity
    2004-02
    17
    Default Please HELP: how to modify a TOLERANCE entity
    Hello again, I got a new challenge for you great AutoLISP experts:
    You know that if you 'Left-click' on a TOLERANCE entity in an AutoCAD drawing the TOLERANCE windows appears and you can modify the previous inserted data.
    How can I do this from inside an AutoLISP routine (supposed I know the name of the TOLERANCE entity and without asking to manually select the TOLERANCE from the drawing)?
    Thanks a lot...again!
    Still Alberto, still working hard!
    AUGI Addict fixo's Avatar
    2005-05
    Pietari, Venäjä
    1,269
    Default Re: Please HELP: how to modify a TOLERANCE entity
    Hi,
    Maybe this will help you:
    (setq tol (car (entsel "\nSelect tolerance entity\n")))
    ;;;or:
    ;;;(setq tol (entlast)) if you create this before with command
    (initdia)
    (command "._ddedit" tol "" pause)
    Thank you
    2004-02
    17
    It's exactly what I was looking for!
    Thanks a lot to FIXO and to this great community!
    2005-05
    Pietari, Venäjä
    1,269
    Glad to help you
    Thanks
  1. Replies: 1
    Last Post: 2010-02-23, 02:57 PM
  2. Modify Floors > Modify Sub Elements
    By diesellam in forum Revit Architecture - General
    Last Post: 2010-02-23, 01:53 PM
  3. Tolerance from Keyboard
    By kevinthenerd in forum AutoCAD General
    Last Post: 2009-02-25, 09:16 PM
  4. Proxy Entity Code 310 to Normal Entity
    By KevinBarnett in forum AutoCAD General
    Last Post: 2005-05-26, 07:21 AM
