Thread: .shp file object data to CAD properties
    2005-06
    7
    Default .shp file object data to CAD properties
    I am a new Map 3d 2006 user and I would like to know if there is a way to convert
    the elevation object data from a .shp file to the objects properties.
    I am trying to assign elevations to contours which I brought into CAD from .shp
    files.
    2002-02
    Saskatoon, SK Canada
    23
    Default Re: .shp file object data to CAD properties
    Hello aws.89861,
    Yes, this is possible, however there are a few steps...
    1) Import the SHP file into Map, and save the dwg (Dwg A).
    2) Start a new dwg, and attach Dwg A (Map attach, not Xref)
    3) Create a query to bring in the required data, and use the 'Alter Properties feature to read the Object Data, and set the elevation of the objects queried in.
    Hope this helps
    Warren M
    2005-06
    7
    Thanks Warren,
    Now I will need to learn how to build the query. I am not sure if I select property or data
    type but I will try both
    2002-02
    23
    Hello aws.89861,
    Incase you haven't found it yet...
    The query could be a simple 'Location All' query, but the Alter Properties will be based on the Object Data (Data).
    Hope this helps
    Warren M
    2005-06
    7
    Thumbs up Re: .shp file object data to CAD properties
    Thanks again Warren. I learned that I was missing a couple of crucial steps in building the query. 1. I did not have the draw bullet checked and 2. I would set up the query and click on OK instead of ADD when in the alter properties dialog box. I have been successful with this task now.
  1. 2014: Added object data fields to Polyline, but object data is empty or zero
    By tntdraftsol in forum AutoCAD Map 3D - General
    Last Post: 2015-07-24, 12:20 PM
  2. Problem about object data value (import from DGN file)
    By supphachai.s in forum AutoCAD Map 3D - General
    Last Post: 2009-02-16, 04:36 AM
  3. Export Object data to a text file?
    By rob.fryer in forum AutoLISP
    Last Post: 2007-02-20, 01:58 PM
  4. Object Table Data to Properties box
    By m.storey in forum AutoCAD Map 3D - General
    Last Post: 2006-05-25, 11:49 AM
  5. Alter Properties - object data
    By gis.68227 in forum AutoCAD Map 3D - Wish List
    Last Post: 2005-02-04, 05:04 PM
