Thread: Paperspace entities turn all white
    100 Club Ferroequine's Avatar
    145
    Default Paperspace entities turn all white
    Hi All,
    What setting would cause all entities in a layout (both paperspace entities and any displayed through a viewport) to just show up all white? The layers are still set properly, and when you go into the modelspace tab, everything is as it should. I've got it happening in 2004 & 2005. For some reason, 2006 does not seem to have this issue with the same drawing...
    Any input is appreciated. TIA!
    2001-05
    Austin, TX USA
    2,201
    Default Re: Paperspace entities turn all white
    In your page setup, see if "Display plot styles" is checked. Located under the plot style pull down.
    145
    That did the trick. The user claims that they never set it, but you know how it goes sometimes...
    Thanks!
  1. white paperspace objects
    By rstiles in forum ACA General
    Last Post: 2007-11-10, 02:48 AM
  2. Everything appears White n Paperspace
    By rustific41657 in forum AutoCAD General
    Last Post: 2007-03-28, 07:20 PM
  3. Replies: 1
    Last Post: 2006-04-23, 06:16 PM
  4. Drawings displays as white in Paperspace.
    By gary.carr in forum AutoCAD General
    Last Post: 2006-01-31, 05:06 PM
  5. Replies: 0
    Last Post: 2005-07-08, 06:05 PM
